pagination problem
14 years 5 months ago - 14 years 5 months ago #54524
by papaleksi
pagination problem was created by papaleksi
Hello i need your help please.
I have a problem with pagination.
If i have for example 25 items (not random items)and some one make the choice to display by 5 or 10 or 15 or 20 is ok!!
BUT if somebody make the choice of display by 30,50 the pagination options disappear and i can never see them.
Last edit: 14 years 5 months ago by papaleksi.
14 years 5 months ago #54565
Replied by nicolas on topic Re: pagination problem
That's indeed the case.
You would have to edit the file "listing_div" of the view "product" via the menu Display->Views and change the code:
$this->pageInfo->elements->total > $this->pageInfo->limit->value
in order to avoid that.
14 years 5 months ago #54756
by papaleksi
Replied by papaleksi on topic Re: pagination problem
i did it but i still have the same problem
14 years 5 months ago #54842
Please make sure that you did your modification in the file of the template you're using on the front end and not another template. Otherwise, you wouldn't see any difference.
14 years 5 months ago #54866
by papaleksi
Yes Sir i did it front end and in the template i use but did not solve the problem
14 years 5 months ago #54955
Mmm. That works for us.
Did you check that you did the change for all the occurrences of that code in the file ?
14 years 5 months ago #55015
by papaleksi
There was twice in the code but i had make the change only to one place.
now it works to me too.
thank you very much Nicalas!
