Menu/Module display output hierarchy
14 years 5 months ago #54744
by federal
Menu/Module display output hierarchy was created by federal
Hi, not fully understanding the display output hierarchy. With the content menus the output is nice and straightforward if using menu items to select. Whatever you set in each menu item is output as expected.
If however you navigate via the category images (content modules) it would seem that the top level category affects all sub category output? Not a problem if this is supposed to be the case, but as I'm new to the product I'm not sure if I'm doing something wrong?
The option to "Synchronize with currently displayed item when possible" I would have guessed would set the module output the same as the selected menu output? When is "when possible"? and is this in fact what this option does, as it seems to make no difference?
Also I can't remove the associated category?
I'm sure there is some documentation on this somewhere, but what I have found so far doesn't really explain things in a way I can understand.
14 years 5 months ago #54789
Replied by nicolas on topic Re: Menu/Module display output hierarchy
When you display a category listing menu. Whether it's displaying the categories of the top level or their sub categories, it will display the same. That's normal.
The option "Synchronize with currently displayed item when possible" means that when you are on a category/products listing menu which is displaying the elements of a category (that's always the case) the module would also display its elements with that main category for reference.
Take the categories module on the bottom left of the demo website: www.demo.hikashop.com/index.php?lang=en
When you click on the "Shoes" category, the page will display the products listing of the "Shoes" category. But the categories modules still display the same categories. But if you turn that option on for that module, on that page, it will try to display the sub categories of the "Shoes" category and since there are no such sub categories, it won't display anything.
"When possible" means that when the page is not a category/product listing, it's using the "associated category" as "reference" category for the elements. That's why on the home page, you see these categories which are the sub categories of the main product category of the shop.
You can't remove the associated category. That's also normal. If ther eis no reference category for a listing, the system won't know what products/categories to display.
The following user(s) said Thank You: federal
