Categories Menu Links Problems
14 years 4 months ago #55982
by nubelr
Categories Menu Links Problems was created by nubelr
I thought I had things figured out, but...
I've got a menu that lists my shop categories (using hikashop's accordian style menu)... however, there is no line break between each sub category link (the ones that are short words)... they show up on one line... see attached image. I'd like each category link listed out on it's own line.
Also, why is there a category list under the products? How do I remove this?
Thanks!
Thanks!
- Thank you received: 1778
14 years 4 months ago - 14 years 4 months ago #56000
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Categories Menu Links Problems
I think that you'll have to go to your menu and set your "Show sub categories" to no child.
Hope this will help you.
Last edit: 14 years 4 months ago by Mohamed Thelji.
14 years 4 months ago #56006
Replied by nicolas on topic Re: Categories Menu Links Problems
1. You can do like that:
www.hikashop.com/en/forum/4-how-to/41721...ry-list-display.html
2. Edit your menu via the menu Display->Content menus and disable the category listing attached to your menu in the "associated modules" option.
14 years 4 months ago #56018
by nubelr
Yes, that did the trick! Thanks!
Replied by nubelr on topic Re: Categories Menu Links Problems
nicolas wrote: Hi,
