- Thank you received: 14236
UPS Shipping Plugin
14 years 2 months ago #56922
Replied by nicolas on topic Re: UPS Shipping Plugin
Did you test the same values on the UPS online tool for shipping price calculation ?
Do you have the same result than with HikaShop with the same weight/dimensions ?
For example, if you try with the 2 products case:
Weight : 1 LB
Length : 0.965
Width : 0.812
Height : 0.965
If so, and that should be the case, there is nothing we can do as the rates the plugin display are sent by UPS.
Weight : 1 LB
Length : 0.965
Width : 0.812
Height : 0.965
14 years 2 months ago #56995
by kessler
Replied by kessler on topic Re: UPS Shipping Plugin
The rate for 1 piece is the same as my UPS Worldship 2012, but for additional quantities, the rate is higher than UPS Worldship 2012.
- Thank you received: 1778
14 years 2 months ago #56998
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: UPS Shipping Plugin
Can you please tell me :
- how did you configured your test in UPS online tools (screenshot)
- the reslut (screenshot)
- the sender and receiver adress.
14 years 2 months ago #57128
by kessler
I found the problem. The handling charge does not calculate the percentage correctly. Thank-you for your help.
14 years 1 month ago #60521
by mtangelcv
Replied by mtangelcv on topic Re: UPS Shipping Plugin
14 years 1 month ago #60533
by Mohamed Thelji
Can you test it with the last version of the UPS shipping methode ?
14 years 1 month ago #60574
by mtangelcv
EXCELLENT! Thanks MT!
Time to create page: 0.251 seconds
