Default product variant on product listing?
14 years 4 months ago #56627 by zvone
I have two variants on one product x. First variant has id=10 (15g), second has id=11 (50g). Every variant has a different price. I selected default variant in product characterisics - id = 11 (so 50g variant is default). Now the problem is on product listing, the default variant is still id=10, but when I click on product it loads id=11. My wish is to have ability that product listing is also loading the variant that I selected in product options under "characteristics".
Thank you.
14 years 4 months ago #56629 by zvone
I found out that problem is with order of variants. How to reorder order variants anyway? Products have this ability to order (it's standard Joomla function) but variants don't have. Is this possible to achieve somehow?
14 years 4 months ago #56669 by nicolas
The default value of a characteristic can be selected in the Characteristics area of each product.
The ordering of the values of a characteristic is done automatically either alphabetically or based on the order you added the values in the characteristic.
You can select one mode of the other with the corresponding option of the Display tab of the configuration called "Characteristics values ordering".
We have on the todo list the possibility to set an ordering for each value of a characteristic but that's not yet possible.
14 years 1 week ago #77535 by rikatos
I would so love to be able to sort the order of variants, so my vote for this please !
14 years 1 week ago #77601 by Jerome
I have added your request in our TODO list.
13 years 10 months ago #83664 by Stéphane Corbé
zvone wrote: Hi,
... I selected default variant in product characteristics - id = 11 (so 50g variant is default). ...
How can we select the default variant ???
13 years 10 months ago #83832 by Jerome
The default variant value is set in the main product page.
You would have your dropdown lists and the selected values would be the default values.
12 years 5 months ago #159591 by Dibben
Did you implement ordering on variants? I cannot see it on the most recent version of hikashop. I had a request from the customer to have the variant drop downs on the front end product page in alphabetical order by default, is this possible?
Alex
12 years 5 months ago #159597 by Mohamed Thelji
Hello Alex,
The solution will be to directly to it through the ordering of the value of your characteristic via "Hikashop->Products->Characteristic".
