Recently viewed products
14 years 3 months ago #58051 by indianpresley_0028
Good afternoon,
How do I made some coming in order to see the recently viewed products? Since I found in the configuration that the option for the recently viewed products are already set to yes and it's not working.
14 years 3 months ago #58054 by tony@10uk.net
This any help?
www.hikashop.com/en/forum/4-how-to/50171...ly-viewed-items.html
It still doesn't work for me under HS 1.5.7 Business Edition.
Nicolas suggested it may have problems unless I upgrade but I don't generally upgrade unless I find a very good reason to do so, and this wasn't serious enough to justify it so don't know if would work in latest version.
Tony
14 years 3 months ago #58128 by nicolas
The default options in the display tab of the configuration are for new listings. For existing ones, you will find the same options in the hikashop options of your menus/modules via the menu Display->Content menus/modules.
Thanks for the link tony@10uk.net
That indeed gives good advice on the options and indeed, there were some issues with that option in previous versions of HikaShop so I encourage you to use the latest version if you want to use it.
