Recently viewed products
14 years 3 months ago #58175 by indianpresley_0028
Ive tried it a while but still dosen't work
14 years 3 months ago #58202 by Mohamed Thelji
You'll just have to create a normal products listing module and in the hikashop options of the module, turn ON the "recently viewed" option and it should work.
Hope this will help you :).
14 years 3 months ago #58217 by indianpresley_0028
Im just tour about the configuration. can i used the coding for viewing the recent products?
but I don't know the code for displaying the recently viewed products which i found in the views all the functions/files needed
14 years 3 months ago #58273 by nicolas
You want to display the recently viewed products or the recently added products ?
In any case, you will have to create a products listing module:
www.hikashop.com/en/support/documentatio...html#products_module
and then configure its hikashop options in order to display the products one way or another.
