- Thank you received: 1
Display product images larger
- pinghsinlee
14 years 3 months ago #59458
by pinghsinlee
Display product images larger was created by pinghsinlee
Hi I am trying to get a larger image of my product to show up. I tried changing the DIV options in the product module but this does not seem to change anything. See my image below for the page and the configuration.
Thanks all!
Thanks all!
14 years 3 months ago #59460
Replied by nicolas on topic Re: Display product images larger
That can be changed in the "Files" tab of the configuration.
- pinghsinlee
14 years 3 months ago #59462
by pinghsinlee
Replied by pinghsinlee on topic Re: Display product images larger
Nicholas,
If i change that in the files tab of configuration, then how does the "product list" menu options affect the image?
I guess i am confused because there are multiple places where images size can be set, i do not know which one takes effect. Thanks!
14 years 3 months ago #59520
The menu options do not affect the product page image size.
The menu is a product listing. The image size options affect the size of the images on the listing of course. It's as simple as that.
- pinghsinlee
14 years 3 months ago #59522
by pinghsinlee
Ah Thanks Nicholas, I am new to Joomla so still learning some of the inner workings of menus and modules. Please bear with me for the noob questions.
