Add a heading over related products
14 years 3 months ago - 14 years 3 months ago #60708 by Ennea
How do you display "You may also like..." above related products?
We're mostly linking to category listings and they're set so that any related items will display on product view (which is working), we just want to enter a heading and aren't sure of exactly where to change it because this section isn't using its own module.
Thanks!
Joomla 2.5.6 | HikaShop 1.6.0
Last edit: 14 years 3 months ago by Ennea.
14 years 3 months ago #60790 by nicolas
Normally the related products are displayed with a products listing module.
If you turn on the display of the title of the module, you should see it displayed on top of the listing.
Otherwise, it's also possible to add your text at the end of the file "show_default" via the menu Display->Views and it will display after the product details.
The following user(s) said Thank You: Ennea
