attach products
15 years 9 months ago #6074 by socialbandit
attach products was created by socialbandit
We have 2 products listed for sale on our site www.ecostarllc.net/tutorials/tutorials-overview.html , is it possible to link the product to the shopping cart as they stand or do i have to change the format?
15 years 9 months ago #6075 by nicolas
Replied by nicolas on topic Re: attach products
You can use the link provided in the "add to cart HTML link" for your buttons so that the product will be automatically added to the cart and your users directed to the checkout.
15 years 9 months ago #6085 by socialbandit
Replied by socialbandit on topic Re: attach products
great , now why am i getting 2 prices 1 in dollars the other in euros , how can i customize this page , the fields for countries shows France and the region Rhone , can i add my product image to this page too?
15 years 9 months ago #6088 by nicolas
If the price of your products are in dollar but that your main currency is euros (in the config under the main tab), the system will convert the prices to the other currency. Then, based on the options in your configuration, it will display both prices or not.
So you should change the main currency (don't forget to logout/login after the change so that you can see your modification on the front end).
The country/state fields default value can be changed via the menu Display->Custom fields.
It's not possible to display your products image there. You can edit the the file cart of the view checkout via the menu Display->Views to add your product image, but that require some coding skills.
15 years 9 months ago #6092 by socialbandit
Replied by socialbandit on topic Re: Custom fields
i think i screwed up something in the address _ country field in the custom fields , i dont have the drop down for menu for country nor region any more any advice on how i can restore this?
15 years 9 months ago #6093 by nicolas
Replied by nicolas on topic Re: Custom fields
Could you edit that custom field and make a screenshot of its options ?
15 years 9 months ago #6097 by socialbandit
please find the screen shot attached
15 years 9 months ago #6100 by nicolas
In the "zone" option, you set it to display states. You should set it to display "countries" and save. That should fix the problem.
