some little problems...
14 years 2 months ago #62797 by juls
some little problems... was created by juls
I’m a absolute beginner in this – and my english is not the best but I hope you might understand my questions and that someone can help me...
1. I created two categories – one for print products and one for gym equipment. Is it possible to assign each category a discount (for example for the printproducts 12 % and for the gym products 20 %)? I read in another theat that you can do this by characters – but the problem is that if I want to create a character I can enter just the name – nothing else (see screenshot Hikshop_charactersbug) Is this a bug oder do I made some mistakes?
2.I have some problems with the payment modulation – is there any payment just for invoice?
3. Is it possible to change each „next“-Button in the checkout workflow – so it’s named by the next option (for example „ adress“ – “shippin” – “payment” …)?
4. I have the problem that I have just a “next”-button in the checkout workflow but no “previous” button – where can I change that?
5. Do I have to add a weight on EVERY product to see the shipping information? For some products I don’t know the weights – the shipping is for fee – so the weight doesn’t matter….
6. the “title-”field at the address is named in English (Mr/Mrs/…) - where can I change that into German?
Thank you very much!
Juli
14 years 2 months ago - 14 years 2 months ago #62812 by Xavier
Replied by Xavier on topic Re: some little problems...
Hi juls,
1. The discounts can be applied on categories, in HikaShop > Order > Discounts, create a new discount and affect it only on the category wanted.
2. I think that you can use the "check" method, edit this method name, description and the check information to put the text to display after the order.
3. Yes it's possible, you can read that post which explain how to change the text:
www.hikashop.com/en/forum/4-how-to/9242-...ext-button.html#9242
4. There is no "previous" button, you can edit the view "checkout / step" in HikaShop > Display > Views to add this button, but it require some php skills.
You can too enable the progress bar in the checkout options.
5. You can set a shipping method with a minimum weight of 0kg, then your products don't need a price.
6. The translations can be changed in HikaShop > Configuration > Languages, edit the language file and replace the text between the quotes.
Last edit: 14 years 2 months ago by Xavier.
The following user(s) said Thank You: juls
14 years 2 months ago #62861 by juls
Replied by juls on topic Re: some little problems...
Hi Xavier,
thank you very very much for the help!!!
I created two different discount but where can I affect it only on the category? We just got the essencial version - might be that this option is just for the bussiness version?
Thanks for the tip for question 2,3 and 5 with the check method - it works perfect!
I'm gonna ask someone how requires phpskills to help me with nr4..
And just one more quetion to nr.5:
I try to finde the file in the languages but I coudn't find it... Where can it be?
Greetings
Juli
14 years 2 months ago #62935 by Xavier
Hi juli,
In the discount form, just add a category, look at this picture:
The languages files are in HikaShop > System > Configuration, the tab languages, then click on the edit button.
In this file search for: HIKA_TITLE_MR.
14 years 2 months ago #62939 by juls
Hi Xavier,
it seems that it doesn't work with our version of Hikashop
We don't have the option to select the category.... :( :( :(
and I couldn't find in file HIKA_TITLE_MR - seems it doesn't exist - just "HIKA_TITLE="Titel"" :-(...
But thanks für your help!!!
Greetings
Juli
14 years 2 months ago #62940 by Xavier
You don't have the essential version installed on your website, only the free version.
That's why you can't apply the discounts on categories.
For the translation, it's maybe due to you version of HikaShop 1.5.5 which is not the last version. Maybe the text has changed, I think it wasn't "HIKA_TITLE_MR".
