- Thank you received: 2
How do you create an Alpha Index for filtering?
- doogledesign
14 years 2 months ago #63151
by doogledesign
How do you create an Alpha Index for filtering? was created by doogledesign
I would like to create an alpha index for filtering products. See the attached image.
What would be the steps needed to create this?
14 years 2 months ago #63378
Replied by nicolas on topic Re: How do you create an Alpha Index for filtering?
You would need to create a custom field of the table "product" and of the type "dropdown" with one value per letter.
Then, in each product you would have to set that value.
Then, create a filter of the type "list" applied on that custom field and it will display a list of links with one value per value of the custom field on your products listings.
The only thing is that it will have one value per line, so you will need a piece of CSS to have them display on one line. Nothing complicated.
- doogledesign
14 years 2 months ago #63398
by doogledesign
Replied by doogledesign on topic Re: How do you create an Alpha Index for filtering?
Thanks so much Nicolas. I have gotten the filter displaying on value per line, now I am trying to find where to modify the css. There is a class created, but I am thinking it would be better to make each letter part of a list and style the list accordingly. Also, any suggestions on how to make the filter display on one line as opposed to a list?
- doogledesign
14 years 2 months ago #63445
by doogledesign
Nevermind. I found the file in question:
administrator/components/com_hikashop/classes/filter.php
The main culprit was the </br>. After I deleted that from the filter I had no more issues.
Thanks!
Thanks!
14 years 2 months ago #63453
You should do that with CSS, like that:
.hikashop_filter_main_div br{ display:none; }
That way, you won't have to do it each time you update HikaShop.
- doogledesign
14 years 2 months ago #63548
by doogledesign
Good point.
14 years 1 month ago #70581
by phamosa
Replied by phamosa on topic Re: How do you create an Alpha Index for filtering?
Hi Nicolas, could you help me?
I have the same request but your explanations are not enough for me.. could you explain some more details on how I have to set up the custom field and the custom filter? There are so many options..
In the filter for example, I can only refer to "custom field" in general but not to the actual alpha index custom field that I created..
14 years 1 month ago #70694
If you set the "apply on" option of the filter to "custom field", you will then see a dropdown with the list of your custom fields of the table "product". If you don't see yours there, it means that you didn't configure it properly.
If you could post screenshots of your custom field/filter, we could tell you what is wrong.
