Delete-able Filter Field problem
- wonderwilson
14 years 2 months ago #63994
by wonderwilson
Delete-able Filter Field problem was created by wonderwilson
I'm having a bit of an issue with a delete-able field in my library. Basically, when you enter some text into the field, the first letter remains before the cross (see attached). Also, it is possible to change the cross graphic for something else?
Darren
Darren
14 years 2 months ago #64025
by Eliot
Replied by Eliot on topic Re: Delete-able Filter Field problem
Hi there,
What kind of filter is it? I can't reproduce the bug so could you give me screenshot of your filter configuration and explain me how you end in this?
- wonderwilson
14 years 2 months ago #64027
by wonderwilson
Replied by wonderwilson on topic Re: Delete-able Filter Field problem
Hi Eliot,
Here's the config:
Darren
Here's the config:
Darren
14 years 2 months ago #64029
by Eliot
It's working well there. Could you give me a link so I can try by myself?
- wonderwilson
14 years 2 months ago #64035
by wonderwilson
14 years 2 months ago #64039
by Eliot
Well it's a strange bug.
Are you using the last version of Hikashop? Did you try to configure a new similar filter?
- wonderwilson
14 years 2 months ago #64043
by wonderwilson
it's 1.5.5 - if i upgrade, will I loose anything, I've done some serious customisation?
14 years 2 months ago #64117
by Eliot
It's a known bug of this old version. The problem is solved for now.
If you edited your views through the Hikashop editor, customizations are saved and upgrading should not affect it.
However, if you are afraid about this upgrade, you can also try to download the last version of Hikashop get the file filter.php in back/classes and try to use it instead of your current filter.php (administrator\components\com_hikashop\classes). Success is not guaranteed since the component evolved a lot but it may works.
BE CAREFUL! In order to avoid any problem, I suggest you to make a copy of the old file if you want to try the file switching.
Same thing if you want to upgrade, make a save of your whole website to avoid any disappointment.
- wonderwilson
14 years 2 months ago #64136
by wonderwilson
Hi Eliot,
That fixed it!
Is there anyway I can change the cross graphic - I see that it is also used on other parts of HikaShop?
Cheers
Darren
That fixed it!
Cheers
Darren
14 years 2 months ago #64158
by Eliot
You can put another image instead of this one in the folder media\com_hikashop\images.
Just rename the icon delete2.png in delete2_old.png and rename your new icon delete2.png
However this image is used in on other part of Hikashop so it will change the icon everywhere.
