Apply Coupon Code To Subtotal NOT GRAND TOTAL
15 years 9 months ago #6642 by jbu2010
Some of my customers are tax exempt. So once they provide proof that they are exempt, I want to give them a coupon code to use to take off the tax from the order.
Right now, I have a coupon setup with the percentage of 8.25% (same as the tax that is being charged). But the cart is calculating the total from the subtotal (total price + tax amount). When the coupon needs to be calculated BEFORE the tax amount is added.
HELP!!
15 years 9 months ago #6645 by JWeb5
There is an option in config to apply discount before or after tax
15 years 9 months ago #6647 by JWeb5
system-> config->main tab on the left pane
15 years 9 months ago #6649 by jbu2010
Thank you for the feedback. I've tried both options in the configuration and did some testing after changing each option. The calculation is still not correct. Any other ideas?
15 years 9 months ago #6664 by nicolas
Coupons in hikashop are always used on the taxed price.
The discount before/after tax option is only for discounts.
One solution would be to create a discount and restrict it to a group of joomla users using the access level feature of hikashop business. Then, you could move that user to that group of users so that the discount is automatically applied to your products prices.
Another option could be this:
Edit your tax rule so that it apply only to individuals. Then, in the config make sure that the default user type is individual.
Finally, in Display->Custom file, publish the file address_company, remove it from the front end, and change its type to be a radio button.
That way, you could ask your users to register to our website via the hikashop registration screen so that they enter their company address (or you could do it for them), and on your end, you would be able to activate their address as being a company address. That way, the tax will automatically calculated to remove the VAT on the checkout, once they select their address.
The following user(s) said Thank You: dilum_tharaka
