Checkout row display problem
15 years 9 months ago #6646
by jasonm
Checkout row display problem was created by jasonm
15 years 9 months ago #6662
Replied by nicolas on topic Re: Checkout row display problem
You should try to override the row1 css of your template by adding the CSS below to the hikashop front end CSS in the config under the tab display:
#hikashop_checkout_cart tr.row1 { background : #FFF }
15 years 9 months ago #6750
by jasonm
Replied by jasonm on topic Re: Checkout row display problem
No that didn't work, would it be easier to stop the rows alternating ie declare them all as row 0 rather than 0,1,0,1?
15 years 9 months ago #6754
Did you save your configuration so that the new CSS file is used and did you clear your browser's cache ?
Maybe your modification isn't visible because of that...
Otherwise, yes, you can go in the menu Display->Views and edit the file cart of the view checkout and remove the class on the tr tag.
15 years 9 months ago #6757
by jasonm
I work in Firefox and test changes in a clean IE just to avoid the cache issue.
Class removed and now working OK, thanks Nicolas.
