- Thank you received: 2
onAfterOrderCreate iterating through products
14 years 1 month ago - 14 years 1 month ago #66736
by GeoffM
onAfterOrderCreate iterating through products was created by GeoffM
I'm not proficient in PHP or Hikashop, and simply need a few lines of code to link Hikashop to some existing code. I can get my callback to fire after an order has been processed in the shop but I'm at a loss how to actually get at the data in the order. I seem to be going round in circles with the doco and searching.
So can somebody fill in the blanks please? Given the $order parameter, I want my function to be called once for each product ID in the order.
The User ID has to be the Joomla one, not anything Hikashop creates. There might be some configuration item I need to set to force Hikashop to only allow checkout with a logged-in user. Thanks.
function onAfterOrderCreate(&$order,&$send_email){
if(!empty($order->order_id)){
<foreach product in $order>
my_function(productID, userID);
</foreach>
return true;
Last edit: 14 years 1 month ago by GeoffM.
14 years 1 month ago #66941
by Xavier
Replied by Xavier on topic Re: onAfterOrderCreate iterating through products
Try this code:
Try this code:
$class = hikashop_get('class.user');
$user = $class->get($order->order_user_id);
foreach($order->cart->products as $product){
my_function($product->product_id, $user->user_cms_id);
The following user(s) said Thank You: GeoffM
14 years 1 month ago #68115
by GeoffM
Replied by GeoffM on topic Re: onAfterOrderCreate iterating through products
Thank you, that works perfectly. Sorry for the delay in replying. Now, how do I get the order quantity per product? I've tried $product->quantity and $product->count and $product->cart_product_quantity (as per DB table) but none work.
Many thanks.
Many thanks.
14 years 1 month ago #68116
Replied by nicolas on topic Re: onAfterOrderCreate iterating through products
In the order_product table of the DB the quantity column is called order_product_quantity not cart_product_quantity.
So you should do $product->order_product_quantity
14 years 1 month ago #68117
by GeoffM
I was looking at the wrong table then! Makes sense now - many thanks.
