products-listing
14 years 1 month ago #66761 by xrumchik
products-listing was created by xrumchik
please tell me how to create one to display additional fields on the page hikashop-menu-for-products-listing ?
14 years 1 month ago #66959 by Xavier
Replied by Xavier on topic Re: products-listing
Do you mean filters in the products listing page ?
If yes, you can add filters in HikaShop > Display > Filters, and create a new one. You can apply it on some categories, and choose the type of filter you want.
You can find some documentation here:
www.hikashop.com/en/support/documentatio...-filter-listing.html
14 years 1 month ago #67236 by xrumchik
Replied by xrumchik on topic Re: products-listing
you do not understand me. I need to create one additional output fields in the general menu item
14 years 1 month ago #67335 by Xavier
Hi xrumchik,
First you need custom fields on the item type.
Then in you menu configuration (Hikashop > Display > Content menus), check "yes" for the option "Display custom item fields"
14 years 1 month ago - 14 years 1 month ago #67971 by xrumchik
Additional fields are included
Here is an example in the product
I want to have some additional output fields in products-listing
Last edit: 14 years 1 month ago by xrumchik.
14 years 1 month ago #68135 by nicolas
Replied by nicolas on topic Re: products-listing
You created custom fields of the table "product".
As Xavier said, you need to created instead custom fields of the table "item".
That's why you're not seeing them as input fields.
14 years 1 month ago #68311 by alexxmm
Replied by alexxmm on topic Re: products-listing
I need exactly the same fields. How did you do them? I guess you added some custom fields but which parameters did you chose for this kind of fields?
Thanks,
Alex
14 years 1 month ago #68527 by nicolas
You need to select "product" in the "table" option of your custom fields.
That option is only available in the Essential and the Business edition.
14 years 1 month ago #68538 by alexxmm
Thanks for the fast reply. I have tried it already. I created a new custom field and selected "product" under the table options and "custom text" under field type. But regardless of what I typed in, it only showed the word "specifications" on my product page. Which field type do you recommend to type in some additional product information which will be displayed in the shopping cart area of the product page?
And do you have an idea where to change the color of the information button which can be used to explain customer the different options/characteristics? The small blue button with labeled with an "i". Like the buttons on this page demo.hikashop.com/index.php?option=com_h...ow&Itemid=91&lang=en
Thanks a lot,
Alex
14 years 1 month ago #68548 by nicolas
You need to enter some text in your product's custom field in order to see it on the product page.
For the info image, you can change it by uploading a new one in FTP over this file media/com_hikashop/images/icons/icon-16-info.png
14 years 1 month ago #68557 by alexxmm
I filled out each field which was empty when selecting fieldtyp but it only "specifications" is displayed on my product page even i didnt wrote it.
14 years 1 month ago #68561 by alexxmm
I entered one sample at Hika demo back end (its the one with product table). Same as on my website. I dont see the text on the products page only the word specifikations.
Any idea what I did wrong?
14 years 1 month ago #68563 by nicolas
It's working fine as far as I can see.
Are you sure that you have the "front end" option of your custom field turned on ?
14 years 1 month ago #68566 by alexxmm
Do you see the text in den hika demo?
demo.hikashop.com/index.php?option=com_h...e=&Itemid=78&lang=en
I can only see the word "specifications" beneath the shopping cart.Where do you see the entered text?
14 years 1 month ago #68568 by nicolas
You created a custom field of the type "custom text". These fields allows you to display messages on the input form.
So for custom fields of the table "form" that field will display the text on the product edition page, not on the product page.
You should create a custom field of the type "text" if you want to enter information on the product and that it displays it on the product page.
14 years 1 month ago #68572 by alexxmm
It works now with selecting "item" instead of product. With product its still the same problem. What is the difference?
14 years 1 month ago #68577 by nicolas
Custom fields of the table "product" are for you to enter information on the product edition page.
Custom fields of the table "item" are for the user to enter information on the product page.
14 years 1 month ago #68578 by alexxmm
Thanks a lot. So "item" is the right one for me :)
Time to create page: 0.109 seconds
