Losing products on pages
15 years 9 months ago #6765 by JWeb5
I am losing products. The page is only displaying 3 out of 11 products.
I just dropped the tables and reinstalled them but it is still not bringing them up.
Any help would be awesome! Is there a way to split up the items in the tables ie hika_prods1 and hika_prods2 etc to lighten the load on them or is the source of the error something else? PHPMy admin tweeks? SQL mods???? I have no clue where to even start at this point.
Thank you,
15 years 9 months ago #6778 by nicolas
If products are disappearing it must be because of the way you change them.
For example, if you put the products in another category, and remove them from their previous category, they won't appear in their previous category. Do you see your products on your back end products listing if you go in their categories ?
If you import your products via CSV, please make sure that you have a category specified in the categories column for your products. Otherwise, the product's link to its current categories will be removed.
Also, if you limit the number of items to 3 in your products listing module and that the random option is selected, only 3 products will be displayed and there won't be any pagination.
15 years 7 months ago #12579 by JWeb5
Replied by JWeb5 on topic Re: Losing products on pages
My apologies for the delayed response but i got sidetracked on aother project,and we were continuing to drop and reinstall tables almost daily.
I havechecked everythingeccept thelastnote regarding the limiting of 3 items in thelisting module. I'm not sure exactlywhat that is, and /or where tofind it. can you specify alittle more please?
15 years 7 months ago - 15 years 7 months ago #12581 by JWeb5
Also is there any normal reason I should lose "no Image" graphicson certain items? example:http://aquatic-exotics.net/index.php?option=com_hikashop&view=product&layout=listing&Itemid=74
MYSQL issue? any advice on repairing it. I have optimized the tables and dropped/reinstalled,but to no avail.
Thank you!
(some of the pictures aren't even the right ones!)
Last edit: 15 years 7 months ago by JWeb5. Reason: added (.....)
15 years 7 months ago #12582 by nicolas
First, I recommend you to update HikaShop. We fixed and improved a lot of fixes since 1.4.4 and now the thumbnails are generated on the fly if missing so you shouldn't get that image problem.
You need to go in the menu Display->Content menus/modules. There edit your menus and modules and make sure that the random option is turned off so that you get the pagination and check the option "number of items" as well.
15 years 7 months ago #12584 by JWeb5
i dont see"number of items"as an option in the hika menu.
15 years 7 months ago #12588 by nicolas
Could you do a screenshot of what you see ?
15 years 7 months ago #12589 by JWeb5
i found it. random items is turned off, the pagination is stillnot displaying and the page itself is in the same state. it is set to allow 10 products and the category contains 12. so i am missing 2 products, a few images that are the default no image and some of the images are displaying on the wrong product?
I submitted a ticket to my host provider to have them run test on the db, but via phpmyadmin it looks fine to me.
cleaned and purged all cache and browser also, no change.
15 years 7 months ago #12590 by nicolas
Could you do a screenshot of the options of your menus/modules ?
15 years 7 months ago #12592 by JWeb5
back end
15 years 7 months ago #12593 by JWeb5
front end
15 years 7 months ago #12595 by JWeb5
all ofthe module/menu options are the same in every item/option.
15 years 7 months ago #12596 by JWeb5
these are all of the menu items i have....problem?
15 years 7 months ago #12598 by JWeb5
i deletedall of the images in the media/com/thumb file and that repaired the loss of images/dropping of images. but now everything that was added as an imageviaabsolute path is gone, and how would i go about creating new thumbs for everything? disallow and reallow thumbs via config?
15 years 7 months ago #12600 by nicolas
As I said previously, you should update hikashop. The thumbnails will be recreated on the fly in newer versions.
In your first screenshot, your settings are fine and you should indeed see the pagination... Not sure on what's going on.
15 years 7 months ago #12605 by JWeb5
i did,but i deleted the conficting images files after the fact. it may be that there is no pagination on that page because 2 of the items are not displaying. They show in the back end but not on the front. It's really baffleing
15 years 7 months ago #12612 by nicolas
What if you increase the "number of items" option to something like 50 ?
15 years 7 months ago #12737 by JWeb5
NO luck. still no pagination and still only 10 of 12 in the front end.
here is a screen shot of the back end showing12 in that category.
15 years 7 months ago #12747 by nicolas
Could you give us a back end access to your website so that we can check all that up ?
15 years 7 months ago #12756 by nicolas
Thanks. We'll look at that later today.
