Changing layout on product and making font bigger
15 years 9 months ago - 15 years 9 months ago #6775 by meqrinda
How do I make the link sit on top and make the font bigger?
Last edit: 15 years 9 months ago by meqrinda.
15 years 9 months ago #6792 by nicolas
You need to go in the menu Display->Views and edit the file listing_img_title of the view product. There you can move the code:
<span class="hikashop_product_name">
<?php if($this->params->get('link_to_product_page',1)){ ?>
<a href="<?php echo $link;?>">
<?php }
echo $this->row->product_name;
</a>
<?php } ?>
</span>
at the top of the file.
If you want to change the font size of the product name, you can go in the config under the tab display and edit your CSS and add something like this:
.hikashop_product_name{ font-size: 2em; }
15 years 9 months ago #6804 by meqrinda
I tried with moving the code to the top, it didn´t move.
The font worked and is now bigger.
15 years 9 months ago #6805 by nicolas
Are you sure that you edited the correct file ?
15 years 9 months ago #6806 by meqrinda
Found my mistake, thanks for the help!
15 years 9 months ago #6810 by meqrinda
www.infossa.com/lifestyle.html
Where do I change the margin properly, i tried changing the same section as the big fontsize was.
With a:
margin:10px;
But that didnt change anything.
15 years 9 months ago #6812 by nicolas
You can use:
line-height: 1em;
15 years 9 months ago #6813 by meqrinda
span.hikashop_product_name{ font-size: 2em; }{
display:block;
margin-bottom:5px;
line-height: 1em;
Like this?
15 years 9 months ago #6814 by nicolas
No, you can't have two groups of brackets in CSS. It should be:
line-height: 1em;
15 years 9 months ago #6815 by meqrinda
