products variants quantities
15 years 9 months ago #6850 by clunky
I have just read all 32 pages and cannot find an answer to my situation.
I have a cake shop, selling cakes with toppings.
The cakes can be bought individually or in multiple quantities.
The toppings can be bought individually too.
Can HikaShop do the following?
Present the user with the product @ £5 with toppings variants @ £1 with a quantity box so that the user can select how many of each topping variant they want to have and then have the cart check to make sure that if they have selected say 13 toppings but only 12 cakes it shows an error?
Maybe a tall order but I need to know.
Cheers
15 years 9 months ago #6852 by nicolas
I would need a bit more information to tell you what is and isn't possible.
You say that "The toppings can be bought individually too". So you mean that a user can go in your online store and decide to just buy toppings, is that it ?
Is there a minimum of toppings per cake ? You say that a cake can have several toppings, but then, you say that have 13 toppings and only 12 cakes in the cart is not possible. Why is that ? If one cake has 2 toppings and the 11 others have only one topping that would be a plausible case, or even if 11 cakes had no toppings and that 1 cake had 13 toppings, or that none of the cakes had toppings and that the toppings were ordered separately since apparently it's something you would like...
So I'm not sure what to answer since I did understand your cases. I hope you can precise what you want to do so I can answer you :)
15 years 9 months ago #6867 by clunky
Hi, many thanks for your prompt reply, greatly appreciated.
In my case each cake can only have 1 topping, so if the customer orders 12 cakes, he shouldnt be allowed to order too many toppings, i.e. 13 toppings.
What I supose I am after is simply a quantity box available for the user to select the number of the variant, and some kind of check mechanism so that the toppings total does not exceed the number of cakes ordered.
How about this...
PRODUCT
Vanilla Cakes @ €10 -> select qty
CHARACTERISTIC
toppings each @ €2
VARIANTS
colours
red -> select qty
blue -> select qty
white -> select qty
Selected cakes + quantities of toppings -> cart
I hope this makes it a bit clearer :-)
15 years 9 months ago #6883 by nicolas
Mm, I think I understand.
Here is what I would do:
1 have one characteristic called "topping" with the values "no topping", "topping1", "topping2",etc.
Then, create a product and attach that topping characteristic to it. Then, click on the "manage variants" button to specify the price of each variant (product+topping selection).
Then, create custom item field (only in the business edition of hikashop) called color as a dropdown with the values "red","blue",etc in the menu Display->Custom fields.
On the product page, of each of your cakes, the user will be able to select the topping he wants, the color and the quantity and click on the add to cart button to add it to the cart with the corresponding color and topping.
Would that meet your needs ?
15 years 9 months ago #6886 by clunky
That sounds interesting, is the demo shop set up to allow for testing this scenario or is the demo just the free version?
Cheers
15 years 9 months ago #6887 by nicolas
The demo website has the Business edition yes so you can test that. Please note that the website is reseted once an hour.
15 years 9 months ago - 15 years 9 months ago #6893 by clunky
I have tried to configure a product called cake, following your suggestions and cannot find a way to select 12 cakes and then different quantities of toppings.
Maybe I am being a bit dumb here, perhaps you can have a look at what I have created and make it work?
It's a bit like having quantities for sub options?
Cheers
Last edit: 15 years 9 months ago by clunky.
15 years 9 months ago #6897 by nicolas
You added a custom field of type product. Product type custom fields can be used for specifications of products and can only be set on the back end.
You should have created a custom field of type "item" as I advised you in a previous post.
15 years 9 months ago #6899 by clunky
Hi, the type is now item and shows the dropdown for colour, so now how would I select say, 3 white and 5 red?
Cheers
15 years 9 months ago #6900 by nicolas
I thought that you wanted 1 color and 1 topping per cake...
Why do you want a quantity for colors ?
3 white and 5 red ? do you mean that you want 3 white and 5 red for your cake product with a topping vanilla ?
15 years 9 months ago #6901 by clunky
Doh! times up, all deleted now.
I added a custom field for qty and it did take the entered value through to the cart, it didn't relate to anything however it just said qty 3.
It needs to relate to the variant really, so that I can select 3 chocolate cakes and then afterwards add 1 red, 1 blue and 1 white topping variant.
Any advice for this?
Cheers
15 years 9 months ago #6902 by clunky
Posts crossed.
I have a vanilla cake, you can choose the different flavour frosting then you can choose to have different coloured sauce on top of each cake or cake/frosting combination.
15 years 9 months ago #6905 by clunky
Imagine an alternative, I need to build a pc.
I need a motherboard, select motherboard manufacturer from dropdown, qty = 1
- then select memory sticks, select stick manufacturer from dropdown and select qty = 2
- and so on...
Cheers
15 years 9 months ago - 15 years 9 months ago #6907 by nicolas
Usually, what you do in that case is this:
You create a motherboard characteristic with the possible values: ASUS KF52 (+0€), RealTek PS56 (+10€)
You create a memory characteristic with the possible values: 1 memory stick (+0€), 2 memory sticks (+10€), 4 memory sticks (+20€).
Then, you add both characteristics to the pc product and click on the "manage variants" button to set the price for each combination.
Last edit: 15 years 9 months ago by nicolas.
15 years 9 months ago #6908 by nicolas
So, I understand that you want two characteristics: flavour frosting and sauce colour.
flavour frosting would have the value: vanilla, chocolate, etc
sauce colour would have the value: red, blue, etc
is that it ?
15 years 9 months ago #6921 by clunky
yes that would be ideal
15 years 9 months ago #6924 by nicolas
Then you can do that. Just create these two characteristics with the values and add them to your cake product and you should be good to go.
15 years 9 months ago - 15 years 9 months ago #6927 by clunky
Cool, and how does the quantity box for the sauces get built and attached to the product?
Any chance that you can quickly create this on the demo so that I can see how you have done it?
I would like to buy 12 cakes with a choice of vanilla frosting, 4 with red sauce, 4 with blue sauce and 4 with white sauce.
Any chance? Pretty please? :-)
Cheers
15 years 9 months ago #6929 by nicolas
Ah, you want a quantity box for the sauces ?
So you mean that you can have several sauces for each cake, and that they can have several colours, right ? Are the sauces free, because you didn't mention the price of sauces so far ?
15 years 9 months ago - 15 years 9 months ago #6931 by clunky
sauces will be at a nominal fee of say £1 each.
Imagine yourself going into a cake shop, you buy 12 cupcakes all with a vanilla frosting on, you can now choose to have decorations, or sauces on all or an some of them, each topping, sauce or whatever you want to call it is at an extra £1 per cake, therefore if you only have 6 with toppings it will be an extra £6. :-)
