Need help on Registration Page
15 years 9 months ago #6946 by 49grill
I installed HikaShop and everything is working fine. However, when I test the check-out procedure, the only issue I have thus far is that next to the log-in form, it says "Registration not allowed"
I can't seem to find where I enable this. Can someone help?
Thanks,
John
15 years 9 months ago #6960 by nicolas
It's in the joomla configuration. You have an option to allow or disallow registration:
docs.joomla.org/Setting_user_registration_policy
15 years 9 months ago #6965 by 49grill
not the same global config in Joomla 1.6 as in joomla 1.5 global config. can't follow the same enablement menu.
15 years 9 months ago #6966 by nicolas
On joomla 1.6, the user registration option can be found like this:
Go in the menu Users->User management and click on the button "options" in the toolbar on the right:
help.joomla.org/proxy/index.php?option=c...6:Users_User_Manager
You will get a popup of options and the first one will be "allow user registration":
help.joomla.org/proxy/index.php?option=c...Help16:Users_Options
15 years 9 months ago #6969 by 49grill
Yes..That worked. Thanks So much. Very much appreciated. that is great.
One more question on the User Registration form, can you tell me how to change the default country and state to the United States?
15 years 9 months ago - 15 years 9 months ago #6972 by nicolas
You can do that in the menu Display->Custom fields. You should edit both the address_country and address_state fields.
Last edit: 15 years 9 months ago by nicolas.
15 years 9 months ago #6986 by 49grill
Perfect. That worked just fine. Thank you so much!
15 years 8 months ago #7664 by MyWorld
Is this not available in the free version as I can't seem to find it. Thank you!!
15 years 8 months ago #7668 by nicolas
It is available. Don't you see the menu Display->Custom fields when you're in HikaShop on the backend ?
15 years 8 months ago #7681 by MyWorld
Ohhhhh I was looking under Configuration > Display
Sorry about that. Thanks!!
