Print issue
14 years 3 weeks ago #69624
by D4E
Print issue was created by D4E
Hi all
i am wondering if there is a way to print the final step of the order. That becouse i want use it for a festival online order, so i'd like the customer to be able to print his order code ad then come to take his stuff.
Any way to do that?
Any way to do that?
- Thank you received: 1778
14 years 3 weeks ago #69671
by Mohamed Thelji
Replied by Mohamed Thelji on topic Re: Print issue
I think that you can do that by using the "Allow users to print their cart" option through "Hikashop->System->Configuration->Checkout".
Hope this will help you.
14 years 3 weeks ago #69772
by D4E
Replied by D4E on topic Re: Print issue
That's true, but the problem is the when printing their card they dont have the order number in that, and that's what i need
14 years 3 weeks ago #69935
Replied by nicolas on topic Re: Print issue
Once the order is created, an email is sent to the user with all his order information. He can print that. Also, if you activate the option "Allow users to print invoices on the front end" if the Display tab of the configuration, the users will be able to print their invoice on their order details page. They have a link to it on their notification email and they can also access to it via a menu item of the type hikashop order listing that you can create via the joomla menu manager.
