How to build a B2B cart with no prices?
- Alexandrakis
14 years 4 weeks ago #72263
by Alexandrakis
How to build a B2B cart with no prices? was created by Alexandrakis
I want to build a B2B site with NO prices. I just want merchants to be able to add products (with no prices shown) to a cart and just submit an order. I need the ability to get the final order while no price is shown. Is this possible using Hikashop? I cannot find a way to do it.
14 years 4 weeks ago #72284
by Xavier
Replied by Xavier on topic Re: How to build a B2B cart with no prices?
You can set no price for the products, then it will display "Free" in the product page, override the translation to replace the text "Free" By "".
Then in Configuration > Display, set "Yes" for the option "Display 'add to cart' button for free products".
And for the cart module, disable the option "Display Price".
You can too override the view "checkout / cart" to remove the price column.
In Configuration > Checkout, remove the steps "Shipping" and "Payment", and you will receive only the orders.
The following user(s) said Thank You: Alexandrakis
- Alexandrakis
14 years 4 weeks ago #72442
by Alexandrakis
Replied by Alexandrakis on topic Re: How to build a B2B cart with no prices?
Yes, now i see. Thank you for your quick response!
13 years 10 months ago - 13 years 10 months ago #84617
by Digiwacht
Replied by Digiwacht on topic How to build a B2B cart with no prices?
I have the same question and i almost got it. It only leaves me with a "Final total 0,00 €" text display. How can i get rid of that?
Last edit: 13 years 10 months ago by Digiwacht. Reason: Forgot the question...
13 years 10 months ago - 13 years 10 months ago #84678
by Xavier
Replied by Xavier on topic How to build a B2B cart with no prices?
You can remove it by css, or by editing the view "checkout / cart".
Here is the documentation for the css: www.hikashop.com/fr/support/documentation/faq.html#css
And for customize the layout: www.hikashop.com/fr/support/documentation/faq.html#pagination
Last edit: 13 years 10 months ago by Xavier.
