Display Product Custom Field in Order Backend View
<?php $class = hikashop_get('class.product');
$productData = $class->get($product->product_id);
echo $productData->CUSTOM_FIELD_COLUMN_NAME;
before the line:
<p class="hikashop_order_product_custom_item_fields">
- Thank you received: 5
Seems like I could filter or sort my orders by their associated product... guessing it is in there somewhere.
It's actually not possible to filter orders by products by default in HikaShop.
Many changes are required to display the products in the order listing, or to filter by products.
We have on our TODO list a thing to develop which will allow to display everything with many filters and apply different actions on it.
Please advise.
How do i answer the question from a boss of "who bought x"? or a customer calling in to say "I think I bought x, can you check?" ?
As Xavier said we'll develop a feature to be able to get such data easily.
Until then if you want to get a list of user names of who bought a product, you can run the SQL query below via phpmyadmin :
For a given product, I need user_cms_id of users who have ordered ALL products (parent and child products) where product_alias = XXX (from hikashop_product).
That is where I need the help.
Here it is:
thanks
Yes you can edit this view in Display > Views, backend template.
And if you have errors when editing, you can still delete the modifications by clicking on the dustbin in the views listing.
thank you.
