Display same custom field value for variants
14 years 3 weeks ago #73254 by wzyefd
I have a question.
When I choose a variant on main product page,the custom fields will disappear.
I realized that I have to input values on variants' edit page again.
If my variants have same values with main product,
What can I do to save the repeat work that input the same values in variant edit page.
So that the custom fields will show on main product page and variant page
14 years 3 weeks ago #73511 by wzyefd
waiting for your replay!!
14 years 3 weeks ago #73518 by wzyefd
I have solved it by myself.
I modify this code in show_block_custom_main.php
<div id="hikashop_product_custom_info_main" class="hikashop_product_custom_info_main">
to
<div id="hikashop_product_custom_info_main1" class="hikashop_product_custom_info_main">
The custom fields will show on the main product and variants.
I don't know the reason , I thought it will cause other problems maybe.
Can someone could give me some advise?
14 years 2 weeks ago #73593 by nicolas
That will be fixed in next version of HikaShop. Until then, your modification is a correct way to solve that.
13 years 11 months ago #78983 by mair
Hi has this been solved in version 2.0?
13 years 11 months ago #79057 by Jerome
Yes, it as been solved in HikaShop 2.0
13 years 11 months ago #79086 by mair
Thanks for the reply Jerome I have the 2.0 business addition and I had to make the changes as described above to the show_block_custom_main.php
Is there a new setting to make it appear in the variants ?
13 years 11 months ago #79284 by nicolas
It could have been that you already had edited one of the view files of the product view before the update and thus you didn't get the modification.
But that's not really a problem since you can easily fix it yourself as you already did.
13 years 11 months ago #82304 by Lemon Tree
I have HikaShop Essential 2.0 - a fresh install, and I have the same problem. It would seem it has not been fixed.
13 years 11 months ago #82463 by nicolas
Can you add the code:
if(empty($variant->$fieldName) && !empty($this->element->main->$fieldName)){ $variant->$fieldName = $this->element->main->$fieldName; }
after the line
foreach ($this->fields as $fieldName => $oneExtraField) {
in the file 'show' of the view 'product' via the menu Display->Views and try again ?
13 years 11 months ago - 13 years 11 months ago #82497 by Lemon Tree
nicolas wrote: Can you add the code:
after the line
Thanks, Nicolas. Can you advise do we ALSO have to make the change suggested above by wzyefd to the file show_block_custom_main.php?
Last edit: 13 years 11 months ago by Lemon Tree.
13 years 11 months ago #82691 by nicolas
The following user(s) said Thank You: Lemon Tree
