Options for products in Categories
14 years 4 days ago #73374
by dima
Options for products in Categories was created by dima
Could U help?
Is it possible to show list of options for each product on category page?
Could U help?
14 years 3 days ago #73561
by dima
Replied by dima on topic Re: Options for products in Categories
14 years 2 days ago #73611
Replied by nicolas on topic Re: Options for products in Categories
You can do that by creating custom fields of the table "item" via the menu Display->Custom fields in the Business edition and turning on the hikashop option "Display custom item fields" of your products listing.
14 years 2 days ago #73638
by brian662
Replied by brian662 on topic Re: Options for products in Categories
I am having a similar problem.
I created a custom product field. I included a graphic showing how I set it up
IN the "configuration/display/Default parameters for products box" I set Display custom item fields to yes.
It does not show in the product page " dev2.4mymerles.com/index.php/collars-leashes "
The custom field does not show
Brian
Brian
14 years 2 days ago - 14 years 2 days ago #73759
by dima
Hi, Nikolas, brian662,
I wonna show U what I want.
I have options for product:
product page
{BLACK|WHITE} for example
I want to show those options for each product (if it defined for this product) on category page:
category page
product page
category page
Last edit: 14 years 2 days ago by dima.
14 years 6 hours ago #74014
As I said, you can do that by creating custom fields of the table "item" via the menu Display->Custom fields.
The custom field that you created is of the table "product", not of the type "item". Delete it and create it properly and it will work.
The following user(s) said Thank You: brian662
14 years 26 minutes ago #74048
by brian662
Great - the table 'item' was counter-intuitive to me, mais il marche, at juis suis tres content.
Brian
Brian
12 years 3 months ago #164351
by comonweb
Replied by comonweb on topic Options for products in Categories
Bonjour Nicolas,
Nous avons suivie la procédure et cela fonctionne mais nous voulons pas afficher les mêmes options a tous les produits
chaque produit a ses propres variantes et c'est les variantes que nous désirons afficher dans la page qui liste tous les produits d'une catégorie, afin d'éviter de cliquer sur : choissir une option
est ce possible?
merci
stéphan
est ce possible?
merci
stéphan
- Thank you received: 1778
12 years 3 months ago #164464
by Mohamed Thelji
Replied by Mohamed Thelji on topic Options for products in Categories
La solution sera probablement d'ajouter tous les produits devant contenir le champs personnalisé dans une catégorie, puis ajouter cette catégorie via l'option de restriction "catégorie" de la page de configuration de votre champs personnaliséNous avons suivie la procédure et cela fonctionne mais nous voulons pas afficher les mêmes options a tous les produits
