2 problems on check-out page
14 years 3 days ago #73572 by zoeatdemetra
Please take a look at the attached page. You can view the actual webpage: demetracabinetry.com/demetra-shop-online/checkout.html
2 problems on the checkout page:
1.Shipping method / payment method : title is missing
2.Image is too big and it pushes the text out of the boarder line.
I am new at Hikashop and green with CSS codes, can you advise me how to solve above problems more specificly? Thank you!
Zoe
14 years 2 days ago #73706 by Mohamed Thelji
Hi Zoe,
Did you edit the "Cart" file of the "Checkout" view of the front-end template that you are currently using ?
14 years 2 days ago #73788 by nicolas
You can add that CSS to display the titles:
#hikashop_checkout_page legend {
color: black !important;
And for the images you can add that CSS:
.hikashop_cart_product_image_thumb img{
height: 40px !important;
14 years 2 days ago #73811 by zoeatdemetra
For the problem 1, firstly I didn't edit the "Cart" file of the "Checkout" view of the front-end template. The weird thing is that it didn't show on the computer screen but when I print it (to PDF) it appears in light grey color. See attached.
For the CSS coding you instructed, I don't know which file to use for adding those on? Is there any specific place that i should add on or just add on the very end?
Thank you!
14 years 1 day ago #73927 by Mohamed Thelji
1. You didn't attached any PDF :).
2. You should add this CSS code through "Hikashop->System->Configuration->Display->Front-end CSS File"
13 years 11 months ago #74097 by Andyfoo
HIghlight the area where those titles appear to be missing with your cursor, and you will see that the words are there in white. Maybe there is CSS somewhere designating those titles as white.
13 years 11 months ago #74380 by nicolas
The CSS code I told you to add on your website will force their color to be black:
13 years 11 months ago #74593 by zoeatdemetra
Nicolas,
I tried to add your CSS code on below two files, but seems it doesn't work.
- "Cart" file of the "Checkout" view of the front-end template.
- "shipping"file of the "checkout" view of the front-end template.
I added the code on the very end of the file. Is it the right place?
Zoe
13 years 11 months ago - 13 years 11 months ago #74701 by Mohamed Thelji
Hi Zoe,
If you have to add any CSS for Hikashop, you'll have to do it through "Hikashop->System->Configuration->Display->'Front-end CSS File'".
Hope this will help you.
Last edit: 13 years 11 months ago by Mohamed Thelji.
13 years 11 months ago #75117 by zoeatdemetra
Thanks! Yes that works after I put it in the front-end CSS file!
However, another problem regarding the image, see attached, the image is not showing there unless you click on it. How to make it showing with a small thumbnail?
Thanks!
13 years 11 months ago - 13 years 11 months ago #75234 by Mohamed Thelji
I think that the problem is coming from the fact that you changed the "Cart" file of the "checkout" view of the front-end template that you are currently using.
If that's the case :
- Could you save your modification in another file and then revert your changes through the "delete" button in front of your "Cart" file ("Hikashop->Display->Views") ?
13 years 11 months ago #75411 by zoeatdemetra
Thanks for the reply.
I don't think I changed the "CART" file of the "checkout" view of the front-end template, If I did, that must be by accident.
Before I do anything, to avoid messing up other stuff, I want to make sure I understand you correctly. Please see attached, do you mean I can click the "delete"(remove customization) button as circled out there?
13 years 11 months ago #75539 by nicolas
Yes, that's indeed what Mohamed meant.
If you see the delete button, it means that you had edited it previously.
13 years 11 months ago #75998 by zoeatdemetra
I deleted the modification on the "cart" file at the checkout view of the front-end template, but the image thumbnail is still not showing there.
Please advise what's going wrong?
13 years 11 months ago #76166 by nicolas
Then it means that either you're not using the latest version of HikaShop or that the folder media/com_hikashop/upload is not writable (in that case, you should check its permissions via FTP).
13 years 11 months ago #76167 by Xavier
Your problem come from the thumbnails, I think that you had changed the thumbnail size parameters, so HikaShop is searching the images in the folder with the new dimensions.
Try to remove and add the images in the product edition page in HikaShop. This will generate the thumbnails with the good size, and then they will be displayed fine.
13 years 11 months ago #80010 by condorazul
i´ve already changed and tried wih other size and nothing is displayed.
13 years 11 months ago #80048 by Xavier
Time to create page: 0.136 seconds
