Need help to find reporting feature in my hikashop
- Socrates Mechanicos
13 years 11 months ago - 13 years 11 months ago #74662
by Socrates Mechanicos
I have installed the Business Version of hikashop.(Dev Site:
emiliarossi.com.au/demo
I am not able to see the reporting feature anywhere in this installation.
I have some doubts regarding the version which I am using
1) from where should I find which version of hikashop exactly I am using. - when I clicked 'Help'->'update/About' menu I got the page which shows the version as 'Your version is 1.5.8.' But not telling anything like basic, essential or business version used.
2) I am sure that the version is 'Business' as it shows those extra features that are only available with the Hikashop Business edition. Like 'Affiliate program', automatic currency updation, geolocation etc - But as this page shows www.hikashop.com/en/support/documentatio...-report-listing.html ? there is not 'Reports' page available.
If the version dont have must support for different type of reporting function. Can we add it as an addon to the current version. Like plugins or something like that, since we done lots of changes in the core files to meet our design and layout requirements.
Anyways I want these basic report features to be generated
1. Best performing products
2. Best performing categories
3. Top spenders by:
a. Postcode
b. Amount spent in total
c. Buying frequency
And want to know how to manipulate widgets in dashboard to attain these above said results.
Hope o hear from the support team soon.
Thanks,
Rahul TS
3. Top spenders by:
a. Postcode
c. Buying frequency
Thanks,
Rahul TS
Last edit: 13 years 11 months ago by Socrates Mechanicos.
13 years 11 months ago #74677
by Xavier
Replied by Xavier on topic Re: Need help to find reporting feature in my hikashop
The advanced report features are available since the version 1.6.0 of HikaShop.
Thanks to download the last version from our website, the version is 2.0
13 years 11 months ago #74724
Replied by Socrates Mechanicos on topic Re: Need help to find reporting feature in my hikashop
Thanks Xavier for your reply,
As I said earlier I have done lots of updates and small tweaks on the core php code of hikashop to meet our design requirements, so I think its not practical to just update the latest version over it.
Is there an easy way by which I can just copy these new features to my older version 1.5.8 just like putting an addon or plugin.
Excited to hear from you.
Rahul
Rahul
13 years 11 months ago #74765
by Xavier
The reports require so many modifications in HikaShop, we have edited a lot of files in the core like helpers classes, etc...
So it's not possible to give you some parts of code concerning the reports, the only way is to update.
