Product display in module ?
im just testing somethings, but i cant seem to get it to work...
made a setup with top modules.
top1,top2,top3,top4
I want to fill these with a category on hikashop.
Example: shop.keukenfraneker.nl/
but when i click the category i get a error... does not excist...
What am i doing wrong ?
- Thank you received: 1778
I don't think that this error is related to HikaShop.
Can you turn off the debug mode of the joomla configuration, and test it again ?
How have you got created these modules ? Can you give us a screenshot of your modules configuration ?
To do that, and I think that you have done this like that, you have to create new modules with the type products listing or category listing, then assign it to a position in the joomla options and allow the display where you want.
I make a new module (hkashop content) then i set the hikashop options.
hope this helps.
its still onMohamed Thelji wrote: Did you turned off the joomla debug mode ? ("Control Panel->Global configuration->System->'Debug System'")
no error as far as i can see
Could you try to turn off the SEF option of the joomla configuration and see if that helps ?
nicolas wrote: It sounds to be a problem related to the SEF.
i turned it off and now it works fine... but i get those long urls... what can i do ?
cause i dont get it to work like this
I have made 4 modules:
top1 = keuken
top2 = badkamer
top3 = buitenkeuken
top4 = vloeren
In my hikashop i have these categories:
main keuken
-> keukenapparatuur
main badkamer
-> badkamer
main buitenkeuken
-> buitenkeuken
main vloeren
-> vloeren
(the '->' are the sub wich need to be shown on de module)
To make a module i do:
New > Hikashop content module > then select the 'main keuken' in categorielisting.
It does show the categorie but not the right link...
It is not e menu modules
But the links work ?
What do you mean by "not the right link" ?
What is the link and what you would like it to be ?
is does not show the right one...
here is the site: shop.keukenfraneker.nl/
Inbouwapparatuur link now is: shop.keukenfraneker.nl/category/13-inbouwapparatuur
it misses the main categorie 'main keuken'
correct link: shop.keukenfraneker.nl/component/hikasho...-sanitair?Itemid=121
now that i have clicked the link once, its changes to: shop.keukenfraneker.nl/category/15-sanitair
wich again is the wrong link...
i have set it to menu_item_root and it works now too
