Same product, two prices. - SOLVED
14 years 4 days ago - 14 years 8 hours ago #76803 by yellowhousejake
I am being asked if we can create a product that has one stock level, but two prices. For instance we have ten books, the books are all identical but if purchased by an adult cost $5, if purchased by a child cost $2.50. Either way, the stock level is decreased regardless of which price was paid.
I am unable to figure this one out. We are using 1.5.6 business version.
Thanks,
Dave
Last edit: 14 years 8 hours ago by yellowhousejake.
14 years 3 days ago #76890 by Xavier
Replied by Xavier on topic Same product, two prices.
Yes it's possible with the business edition of HikaShop, in the product edition page, you can add as much prices as you want.
You can restrict them to a user group, or a currency.
14 years 3 days ago #76952 by yellowhousejake
Yes, but I would need to create a child user group or something like it. I need to be able to have a customer adult and get a book at one price, select child and get the same book at another price. I don't think I can do that.
DAve
14 years 3 days ago - 14 years 3 days ago #77010 by yellowhousejake
I did get it to work! Once it thought about it differently the answer was pretty simple. I used characteristics to create two prices, and it works. Unfortunately it breaks the "Continue Shopping" button by replacing it with a second add to cart button.
DAve
Last edit: 14 years 3 days ago by yellowhousejake.
14 years 3 days ago #77159 by Jerome
Replied by Jerome on topic Same product, two prices.
It breaks the "continue shopping" ?
Can you give us a screenshot ?
Best regards,
14 years 12 hours ago #77489 by yellowhousejake
Sure, the first screen shot is the default that loads as the product comes up, Adult. The second one is the result of choosing the youth ticket or characteristic. You can see where the "Continue Shopping" button is replaced with a second "Add to Cart" selector.
The div in question looks like this in the beginning.
<div id="hikashop_product_quantity_main" class="hikashop_product_quantity_main" style="float:right">
<input id="hikashop_checkout_shopping_button" class="button hikashop_cart_input_button" type="submit" onclick="var field=document.getElementById('hikashop_product_quantity_field_4');history.back();return false;" value="Continue shopping" name="continue_shopping">
</div>
And is replaced with the following.
<div class="hikashop_product_stock">
<input id="hikashop_product_quantity_field_2" class="hikashop_product_quantity_field" type="text" onchange="hikashopCheckQuantityChange('hikashop_product_quantity_field_2',0,1);" name="quantity" value="1">
<input class="button hikashop_cart_input_button" type="submit" onclick="var field=document.getElementById('hikashop_product_quantity_field_2');if(hikashopCheckChangeForm('item','hikashop_product_form')){ return hikashopModifyQuantity('229',field,1,'hikashop_product_form'); } else { return false; }" value="Add to cart" name="add">
</div>
</div>
DAve
14 years 9 hours ago #77553 by Jerome
You should use the id "hikashop_product_quantity_main" for your template custmization.
Please change it with another (unique) id and the javascript won't update the div anymore.
The following user(s) said Thank You: yellowhousejake
14 years 8 hours ago #77562 by yellowhousejake
Well....... dang it. I changed it and everything is working. Thank you.
DAve
