MouseOver Effect For Product Images for2.0hikashop
14 years 1 week ago #76851 by ousia2
Dear hikashop support:
I wish can create move over effect on product images in hikashop2.0(we dont have to click on the image to see large image rather then when we point the mouse over the image it shows the large image instead of clicking it), i found this topic but it is for hikashop1.5.6( www.hikashop.com/en/forum/4-how-to/42708...ct-images.html#42708 ) now the code has been changed in2.0,please someone who can help me ?
14 years 1 week ago #77083 by Jerome
I checked it and I can tell you that even if the popup management in HikaShop 2.0 has changed, the code from the other thread is still compatible.
14 years 1 week ago #77087 by ousia2
ok thank you very much Jerome!
but the the code is different from 1.5.6,did u saw it?
14 years 1 week ago #77107 by Jerome
When I said that it's still compatible, I mean that the fix should still work.
You have to add the
onmouseover="SqueezeBox.fromElement(this,{parse: \'rel\'});return false;"
in the function parameter
'id="hikashop_main_image_link"'
to add this html into the link.
14 years 1 week ago #77163 by ousia2
ok Jerome thank you very much it works ,but can it worked with the category / listing? i mean ,when create a menu link to a hikashop category,can the products image under the category have the same effect? i found the category / listing_img_desc.php, but didn't found a line like 'id="hikashop_main_image_link"'
14 years 1 week ago #77164 by ousia2
maybe is this file?product / listing_.php? add something to here?
<!-- PRODUCT IMG -->
<div style="height:<?php echo $this->image->main_thumbnail_y;?>px;text-align:center;clear:both;" class="hikashop_product_image">
<div style="position:relative;text-align:center;clear:both;width:<?php echo $this->image->main_thumbnail_x;?>px;margin: auto;" class="hikashop_product_image_subdiv">
<?php if($this->params->get('link_to_product_page',1)){ ?>
<a href="<?php echo $link;?>" title="<?php echo $this->escape($this->row->product_name); ?>">
<?php }
echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->file_name), '' , '' , $this->image->main_thumbnail_x, $this->image->main_thumbnail_y);
$main_thumb_x = $this->image->main_thumbnail_x;
$main_thumb_y = $this->image->main_thumbnail_y;
$horizontal = '0';
$vertical = '0';
$this->classbadge->placeBadges($this->image, $this->row->badges, $vertical, $horizontal);
$this->image->main_thumbnail_x = $main_thumb_x;
$this->image->main_thumbnail_y = $main_thumb_y;
</a>
<?php } ?>
</div>
</div>
<!-- EO PRODUCT IMG -->
i wish can MouseOver Effect on Product main_thumbnail
14 years 1 week ago - 14 years 1 week ago #77178 by ousia2
(index.php?option=com_hikashop&view=category&layout=listing ) i mean open this link product's thumbnail can get that effect?
Last edit: 14 years 1 week ago by ousia2.
14 years 1 week ago #77183 by Jerome
The category does not have the same code but the function image->display use same parameters.
So you can put the code in the same argument (last text before width and height parameters).
So replace this :
By this:
echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->file_name), '' , 'onmouseover="SqueezeBox.fromElement(this,{parse: \'rel\'});return false;"' , $this->image->main_thumbnail_x, $this->image->main_thumbnail_y);
14 years 1 week ago #77188 by ousia2
hi jerome i do as you said but looks like it doesn't work (category / listing_img.php)
www.2yuju.com/themelist.html here is my site
14 years 1 week ago #77194 by Jerome
Right, the category listing does not generate a link thanks to the image->display function. The link is just before.
But the link target is the category page, not the full size image. So the modification is a little bit different.
You have to extract the image from the main link, create another link to the fullsize category image and and the onmouseover to this link.
14 years 1 week ago #77196 by ousia2
ok i see,but please can you tell me how to do this? extract the image from the main link, create another link to the fullsize category image and and the onmouseover to this link. please,it is hard to me to do this without your help
14 years 1 week ago - 14 years 1 week ago #77279 by Jerome
Here the code for listing_img_title view (for HikaShop 2.0)
<?php $link = hikashop_completeLink('category&task=listing&cid='.$this->row->category_id.'&name='.$this->row->alias.$this->menu_id);?> <?php if($this->config->get('thumbnail',1)){ ?> <div style="height:<?php echo $this->image->main_thumbnail_y;?>px;text-align:center;clear:both;" class="hikashop_category_image"> <a href="<?php echo $link;?>" rel="{handler: 'image'}" title="<?php echo $this->escape($this->row->category_name); ?>"> <?php if(!isset($this->uploadFolder_url)) { JHtml::_('behavior.modal'); $config =& hikashop_config(); $uploadFolder = ltrim(JPath::clean(html_entity_decode($config->get('uploadfolder'))),DS); $uploadFolder = rtrim(JURI::base(true),'/').'/'.rtrim($uploadFolder,DS).DS; $this->uploadFolder_url = str_replace(DS,'/',$uploadFolder); } echo $this->image->display(@$this->row->file_path,false,$this->escape($this->row->file_name), 'onmouseover="window.hikashop.openBox(this.parentNode,\''.$this->uploadFolder_url.@$this->row->file_path.'\');this.parentNode.href=\''.$link.'\';"' , '' , $this->image->main_thumbnail_x, $this->image->main_thumbnail_y); ?> </a> </div> <?php } ?> <br/> <span class="hikashop_category_name"> <a href="<?php echo $link;?>"> <?php echo $this->row->category_name; if($this->params->get('number_of_products',0)){ echo ' ('.$this->row->number_of_products.')'; } ?> </a> </span>
Last edit: 14 years 1 week ago by Jerome.
14 years 1 week ago - 14 years 1 week ago #77284 by ousia2
:kiss: ok my lord thanks very much for your code
i have copy and paste it to category / listing_img_title.php
but visit my site front-end still doesn't have the effect
14 years 6 days ago #77301 by Jerome
Your page is not a category listing.
