- Thank you received: 2
help with something simple... i hope :)
13 years 11 months ago #77293
by melisari
help with something simple... i hope :) was created by melisari
Im having lot of troubles customizating the access and register part of the hikashop checkout part
I am sure that is something simple, but i dont know much of css and my method right now of changing things is like moving something save and see how it looks with f5
And with this, i already use 3 hours trying.
Thank you so much in advance!
Sue.
Sue.
13 years 11 months ago - 13 years 11 months ago #77305
by Jerome
Replied by Jerome on topic help with something simple... i hope :)
A link to your website would be required to help you for this kind of CSS customization.
It could be quite simple to fix but your problem is link to your template. I guess that "submit input" buttons should have a "float:left" css rule.
A
Should fix your problem but, the button would be placed on his original place : between "remember me" and "forgoet your password".
A
#hikashop_checkout_login_left_part .hikashop_cart_input_button { float: none; }
Last edit: 13 years 11 months ago by Jerome.
The following user(s) said Thank You: melisari
13 years 11 months ago #77382
by melisari
Replied by melisari on topic help with something simple... i hope :)
Of course! Here is the link:
viernezotravez.com
For you can see that page, you will need to add a product to the cart, and then, try to checkout
Thank you so much for your help!
viernezotravez.com
13 years 11 months ago #77401
by Xavier
Replied by Xavier on topic help with something simple... i hope :)
Can you try to add this in your css file:
.hikashop_checkout_page h1{
margin-bottom: 20px;
.hikashop_checkout_login_left_part .hikashop_cart_button{
position: relative;
top: 80px;
left: -350px;
13 years 11 months ago #77414
by melisari
Thank you
I almost got it perfect, i believe my client will be happy with this (he is a little obsesive with the "align" thing)
