Volume Price Range
13 years 10 months ago #80745
by sambob
Don't look at what is and ask 'why?'; look at what isn't and ask 'Why Not!'
Replied by sambob on topic Volume Price Range
13 years 10 months ago - 13 years 10 months ago #81002
by sambob
It is confusing why the listing price is rendered differently in the 'show_default' and 'listing_table' when the original 'listing_price' code is changed.
If I looking into the code (and I am not a coder) for listing_table,
I see that code responsible for rendering the 'listing_price' in 'listing_table' is as follows:
So logic would say that if they both render correctly when default 'listing_price' is used that they render differently when 'listing_price' is changed is caused by a conflict with the code that was changed in 'listing_price'.
Any clues on the conflict?
(Sorry for persistence, but very important that I get the table to display properly.)
<?php
if($this->params->get('show_price','-1')=='-1'){
$config =& hikashop_config();
$this->params->set('show_price',$config->get('show_price'));
if($this->params->get('show_price')){ ?>
<td class="hikashop_product_price_row">
<?php
echo $this->loadTemplate();
</td>
<?php } ?>
<?php
<?php
</td>
<?php } ?>
Last edit: 13 years 10 months ago by Jerome.
13 years 10 months ago #81336
Replied by nicolas on topic Volume Price Range
The problem does not come from the listing_table file but from the way the listing_price file has been modified.
Normally, the "each" text is displayed with the translation system, so a translation override of the PER_UNIT key should allow you to display 1 to 10 instead of each:
13 years 10 months ago #81341
by sambob
Thanks for reply.
Just to clarify, here are the two displays:
1) Table Layout
On this page, it displays each product with,
2) Product Display
Changing the 'each' to say 1-10 in the language file will certainly change the Table Layout, BUT, what if the pricing tier is not 1-10, but 1-100?
Also, just changing the each in the language file doesnt change the second tier, (10+) to be as it is on the product page 10-100.
Does that make sense? (I am wanting the table to display the price ties the same way it does on the product
Thanks for reply.
1) Table Layout
- AU $ 1.51 each
- AU $ 1.26 10+
- AU $ 1.04 100+
2) Product Display
- AU $ 1.51 1 to 10
- AU $ 1.26 11 to 100
- AU $ 1.04 100+
13 years 10 months ago - 13 years 10 months ago #81592
by sambob
Ok... it is down to this
if(isset($this->row->prices[$nextMin])) {
echo ($price->price_min_quantity+1)." to ".$this->row->prices[$nextMin]->price_min_quantity;
} else {
echo ($price->price_min_quantity)."+";
When displaying the results of this (show_price) on the Product Page :
the 'if(isset($this->row->prices[$nextMin]))' argument is true and the prices are displayed via:
( and rendered as 1 to 10, or 11 to 100, etc)
BUT..When displaying products on the Product Table ,
the 'if(isset($this->row->prices[$nextMin]))' argument is NOT True and the prices are displayed via
echo ($price->price_min_quantity)."+";;
( and rendered as 1+ , or 10+ , etc)
So, as both are rendering from show_price, (customized by the code supplied) why is the statement true on one page and false on the other?
Please, I REALLY need this to work
} else {
Last edit: 13 years 10 months ago by sambob.
13 years 10 months ago #81657
by Xavier
Replied by Xavier on topic Volume Price Range
The problem come from that in the listing the products seems to not have the same prices.
Could you give us a backend access ?
The following user(s) said Thank You: sambob
13 years 10 months ago #81734
by sambob
Hi Xavier,
I PM'd the login details
13 years 10 months ago - 13 years 10 months ago #81974
by sambob
Hi Xavier,
You say "The problem come from that in the listing the products seems to not have the same prices",
That's not correct!
I have checked all layouts and the prices are the same for both 'Product Table' and 'Product Default'.
There is something wrong with either the code provided or the way the code is being treated by 'listing_table'.
Without the provided 'Listing_Price' code amendment, both table layout and product display the same. With the code added, they display differently.
That's not correct!
13 years 10 months ago #82030
by Xavier
The problem is that when it's a product listing the $nextMin value should not be equal to $k +1, because the $k isn't incremented by 1 in the listing but by another value.
So it will require more edition in the product_listing view.
Actually we don't have time to provide this kind of code, besides it's a customization, not a bug so it's not our priority.
I suggest you to post a request in the commercial job section of this forum, or ask to a third developer.
Hope that you understand.
Regards.
Regards.
13 years 10 months ago - 13 years 10 months ago #82142
by sambob
A bit dissapointed that it has taken over two weeks to determine.
I am more than happy to pay.
I do think you should consider correcting whatever is creating the conflict for futre editions as tier pricing is very important to many and the default display style is very clumsy.
Yes, I understand.
Yes, I understand.
