Layout problem in product overview
13 years 11 months ago #80027 by Flow
I have two questions:
I have installed another template and now I have a layout problem in the product overview (see attachment). As I continue to click through to the product, everything is good.
When creating articles I can import pictures, but no PDF files. I currently work with a USBWebserver. Could this be the cause?
I hope someone can help me.
Best regards, Flow
13 years 11 months ago #80043 by Xavier
The problem come from your template, I think it override a css property used in HikaShop.
Try to add a width on the class "hikashop_container".
I don't think that the problem come from USBwebserver, it's maybe an access right on your folder which is wrong.
13 years 11 months ago #80056 by Flow
Hi Xavier,
Thanks for your response. The access right of the PDF-folder was wrong.
Where can I get the "hikashop_container"? Sorry for the inconvenience!
Regards, Wolf
13 years 11 months ago #80077 by Xavier
You can find it in the css file in HikaShop > Configuration > Display, Frontend CSS File.
Here is some documentation:
13 years 11 months ago #80087 by Flow
I've seen in Firebug, I need to change the code "width:24%" to ± "width: 28%".
<div class="hikashop_product hikashop_product_column_1 hikashop_product_row_2" style="width:24%;">
But I can not find this code in the CSS file you specified.
13 years 11 months ago #80088 by Xavier
If the code is not present, you can add it.
13 years 11 months ago #80114 by Flow
Am I glad that I did not bought the Business Edition, yet.
I really do not know how I can solve this problem.
Can anyone help?
13 years 11 months ago #80170 by nicolas
Can you give a link to that page so that we can see its CSS ? That way, we could tell you exactly what is the problem and what to do.
13 years 11 months ago #80188 by Flow
I am working offline with the USBWebserver. I first want to try this shop very good
before I put
online. I have made a couple of screen prints.
Regards, Flow
13 years 11 months ago #80193 by Xavier
It's not easy without the page, but try this property:
.hikashop_product_image_subdiv{ width: 130px !important;}
13 years 11 months ago #80214 by Flow
Thanks for your support. It works fine with "width: 170px".
Can you explain to me where I can center the image?
Regards, Wolf
13 years 10 months ago #80236 by Xavier
By default the images should be centered, if they are not it's because they should be smaller.
Try to reduce their size in CSS, or enlarge the div, or adjust with a margin-left property.
The following user(s) said Thank You: Flow
