Caching problem
13 years 9 months ago #82567
by Dzumla
Caching problem was created by Dzumla
Check out this website www.oliverafineart.com/
When I click on "echo of the forest" under 'paintings' on the left it gets a class of 'active current', but when I then click on for example 'fantasy' under 'illustrations', it gets highlighted with a class of 'active current' but that same class remains on 'echo of the forest' as well, until you refresh the page again.
So i get 2 links with a class of 'current active'
I guess this is a caching problem.
Can it be fixed?
Can it be fixed?
13 years 9 months ago #82604
by Xavier
Replied by Xavier on topic Caching problem
You can maybe try to remove the current active class with some jQuery, like "$("#li").removeClass("active");".
But it's not HikaShop related, you can try with other Joomla menu and it will be the same way.
13 years 9 months ago - 13 years 9 months ago #82652
by Dzumla
Replied by Dzumla on topic Caching problem
I think you didn't understand me.
Did you go to the site to see the problem?
I get TWO links with "active" class, but when I refresh only the right one remains with the 'active' class (how it should be).
It is hikashop related problem, this never happened to me before, and it happens with hikashop category listing.
just check the website and you'll what i mean.
Just click anythi under 'Paintings' on the left, and then click anything under 'illustrations' and you will see they both remain with hover effect, but then if you refresh the page only the second one you clicked will have the hover effect (which is the active class).
Last edit: 13 years 9 months ago by Dzumla.
13 years 9 months ago #82868
Replied by nicolas on topic Caching problem
That's a problem which indeed happens with two categories listing module.
Can you try to change the code:
to
in the file components/com_hikashop/views/category/tmpl/listing_list.php ?
That should hopefully fix the problem.
$found = $app->getUserState(HIKASHOP_COMPONENT.'.last_category_selected');
if(JRequest::getString('ctrl','category')=='product'&&JRequest::getString('task','listing')=='show'){
13 years 9 months ago #82964
by Dzumla
Didn't help. that was around like 221 with me. Changed it, but it is still the same.
13 years 9 months ago #83013
Then maybe you're using the "no child" option.
Try to change the code:
to
in the same file.
foreach($this->rows as $row){
The following user(s) said Thank You: Dzumla
13 years 9 months ago - 13 years 9 months ago #83031
by Dzumla
this is on line 87 with me.
It gives me an error.
13 years 9 months ago #83124
by Xavier
Can you give us the error returned ?
13 years 9 months ago #83157
by Dzumla
It actually works with the second solution now.
I guess I made a mistake when I replaced the code, but now when I did it again it solved it! (the second block of code).
Thanks Nicholas! Always helpful with your answers.
Time to create page: 0.282 seconds
