How to hide Stock in Random Products Module
13 years 10 months ago #82707
by RSpreier
How to hide Stock in Random Products Module was created by RSpreier
Actually, I'm not sure I want the stock status to show at all. I also do not want products showing that have a "0" stock status. I selected that in "display" but they still show.
Mainly, I need the stock status NOT to show in the "random products"
Thanks!
Thanks!
13 years 10 months ago #82785
by Xavier
Replied by Xavier on topic How to hide Stock in Random Products Module
You can simply hide it in css, with the property: ".hikashop_product_stock_count{display: none !important;}"
Have you checked "no" for the option "Display out of stock products" in HikaShop > Configuration > Display ?
13 years 10 months ago #82819
by RSpreier
Replied by RSpreier on topic How to hide Stock in Random Products Module
Yes, I have checked NO for Display out of stock.
13 years 10 months ago #82822
by RSpreier
This did not work. Please see here
70.40.211.160/
The "featured Deals" is the random product module.
13 years 10 months ago - 13 years 10 months ago #82825
by RSpreier
OK, I made a mistake, it did work. BUT it leaves a blank space where it should go and still pushes down the add to cart button and screws up the layout. How do I remove this extra space?
ALSO when we imported all of our items from VM to HS all products that had a quantity became a negative quantity. So all items with a - in front of the quantity displays as No Stock.
Can you tell me how to run a query to remove the "-" in front of all of the quantity items?
Last edit: 13 years 10 months ago by RSpreier.
13 years 10 months ago - 13 years 10 months ago #82922
by Jerome
Replied by Jerome on topic How to hide Stock in Random Products Module
About the quantity, HikaShop does not support negative values. The best is to update theses products in order to set "-1" which is a special "unlimited" quantity.
You can do it in the database, with a little SQL request
Just replace "#_" by your database prefix. If it is "jos", the table name would become: jos_hikashop_product.
For your stock display, you can use a CSS rule with "display:none;" or you can override the view which display the stock quantity.
There are a lot of thread which already talk about the stock display modification.
Like: www.hikashop.com/forum/2-general-talk-ab...k.html?lang=en#81468
www.hikashop.com/en/forum/4-how-to/76490...ck-levels.html#80765
UPDATE #__hikashop_product SET product_quantity = -1 WHERE product_quantity < -1;
Last edit: 13 years 10 months ago by Jerome.
13 years 10 months ago - 13 years 10 months ago #83009
by RSpreier
OK, but I do not want unlimted for these. As I said, when we imported the data from VM ALL the quantities changed from a positive value to a negative. So I want to simply remove the '-'
ALSO - in VM we had many products with the unlimited value and simply had the word 'unlimited' in the quantity box. I need to change the word unlimited to the <-1 so I think I can figure that part out based on what you've given me.
OK, I didn't make this work - how do I remove the '-' in front of the amounts?
Thanks!
Thanks!
13 years 10 months ago #83014
by RSpreier
I simply do not want the stock to show in the RANDOM PRODUCTS MODULE where can I find an over ride for this? The CSS doesn't work. I have this in the CSS and it still shows:
.hikashop_product_stock_count {
I may want it to show in the product listing - just not in teh Random Product Module
13 years 10 months ago #83045
by Jerome
It's because you have a missing " } " in your CSS file.
And for the quantities
@media only screen and (max-width: 480px) {
div.modal.fade.in {
width: 320px !important;
height: 380px !important;
margin-left: -160px !important;
top : 10% !important;
left: 50% !important;
table#hikashop_cart_product_listing td:nth-last-child(1), table#hikashop_cart_product_listing th:nth-last-child(1), table#hikashop_clicks_listing td:nth-child(1), table#hikashop_clicks_listing th:nth-child(1), table#hikashop_clicks_listing td:nth-last-child(1), table#hikashop_clicks_listing th:nth-last-child(1), table#hikashop_sales_listing td:nth-child(1), table#hikashop_sales_listing th:nth-child(1), table#hikashop_sales_listing td:nth-last-child(1), table#hikashop_sales_listing th:nth-last-child(1), table#hikashop_leads_listing td:nth-child(1), table#hikashop_leads_listing th:nth-child(1), table#hikashop_leads_listing td:nth-last-child(1), table#hikashop_leads_listing th:nth-last-child(1) {
display: none;
/* Add here your missing } */
/* @media only screen and (max-height: 420px)*/
div.modal.fade.in {
height: 320px !important;
top:0% !important;
.row-fluid .hikashop_product_column_1, .row-fluid .hikashop_category_column_1 {
margin-left: 0 !important;
UPDATE #__hikashop_product SET product_quantity = -product_quantity WHERE product_quantity < -1;
13 years 10 months ago #83060
by RSpreier
Awesome! Thank you Jerome! Both worked.
Is there ANY way I can set it to not show the quantity ONLY in the Random Product Module?
13 years 10 months ago #83061
by RSpreier
Well, it worked, but not the way I want. There is still too large a space where the product count would be - at least I think that's what it is. So it's screwing up the layout on the random products module. Can you please look at the site here:
70.40.211.160
You may have to refresh a few times to see what I'm talking about.
Is there a way to fix this?
13 years 10 months ago #83118
by Jerome
You have two "<br>" after the "<span class="hikashop_product_stock_count">38 items in stock</span>".
You can edit the with and move the "<br>" in the span. At this moment, when the span would be visible, "<br>" would be too and otherwise, you wouldn't have this empty spaces.
Time to create page: 0.158 seconds
