Display dimensions and weight as custom fields?
- Lemon Tree
13 years 11 months ago #82710
by Lemon Tree
Display dimensions and weight as custom fields? was created by Lemon Tree
If I turn on "Dimensions Display" and "Weight Display" in Configuration > Display, then the width, length, height and weight are displayed under the price on the product page. I don't want them there. How can I move them to be displayed under "Specifications"?
What are the variable names for these fields, and can I add them as custom fields? How would I do this? Any other suggestion?
Thanks!
Thanks!
13 years 11 months ago #82772
by Xavier
Replied by Xavier on topic Display dimensions and weight as custom fields?
You have to edit the view "product / show_default" then move the elements in the view "product / show_block_dimensions" under the show_characterirstics block of the show_default view.
It require some PHP knowledge.
The following user(s) said Thank You: Lemon Tree
- Lemon Tree
13 years 11 months ago #83080
by Lemon Tree
Replied by Lemon Tree on topic Display dimensions and weight as custom fields?
It looks a bit too difficult for me, and it is not a priority, so I will leave it for the moment. Thanks for telling me where it needs to be done.Xavier wrote: Hi,
