[SOLVED] CSV import - problems with variants
13 years 11 months ago - 13 years 11 months ago #82932
by Mainzer
[SOLVED] CSV import - problems with variants was created by Mainzer
Can anyone help me with this, I don't know what I'm doing wrong. I already read all post related to CSV on this forum but I don't get it.
First I exported csv file from hikashop and start adding products and variants. I use LibreOffice Calc for that. When I made an import it kind of scrambled some variants and prices were not defined. At import is always the message that I have invalid product codes.
After several tries I decided to clean hikashop database and start over again. So I deleted all the products and variants from hikashop backend. In phpmyadmin I deleted the all the rows and Empty the tables (TRUNCATE) of: hikashop_variant, hikashop_product_category, hikashop_product and hikashop_price.
After this I import a new created csv file (please see atached file), with some products and all its variants with prices. I get this notification: "192 products found, 136 products imported, 14 invalid product codes and 42 already existing products.
Why do I have invalid product codes and already existing products? Did I not deleted them all? What do I have to delete more?
Next I export a new csv file (see attachement) and realized it only imports all main products and only the variants of the last main product in the list. Also some cells of the variants have duplicate values:
If you need more info just ask. I'm trying this for 2 days now. Any help is very appreciated.
regards,
Mainzer
UPDATE: The "14 invalid product codes" is solved, I found the error. All the other problems remain.
regards,
Mainzer
Last edit: 13 years 11 months ago by Mainzer.
13 years 11 months ago #82995
by Mainzer
Replied by Mainzer on topic CSV import - problems with variants
Sorry bordering you.
At last I figured it out.
I gave every variant an exclusive product_name and it worked. (I thought that the name of the variants were irrelevant and that hikashop would automaticly create different prodruct_code for each variant)
But this is very time consuming. I have to import tousands of products, with 12 variants each :ohmy:
Does leaving it blank work?
Is there a faster way to do this?
Thank you,
Mainzer
Thank you,
Mainzer
13 years 11 months ago #82996
Replied by nicolas on topic CSV import - problems with variants
Try to remove the product_id column and import again after a fresh truncate of the table. The rest looks ok in your CSV.
13 years 11 months ago - 13 years 11 months ago #83004
by Mainzer
Hi nicolas,
Like I said in my 2nd post it only worked renaming each variant with an exclusive product name. I didn't need to eliminate the column product_id, only its content.
Isn't there a "automatic" way to do this?
13 years 11 months ago #83019
You need to fill the product_code column for the variants, otherwise, the system will use the product_name as a product_code and if you have several variants with the same product_name, you get the behavior that you have. The product_name can be the same, that's not an issue, but the product_code has to be unique.
If you don't care about the value of the product_code for variants then that's easy to fill up in excel. just enter a number in the first one and have excel generate all the other ones.
The following user(s) said Thank You: Mainzer
13 years 11 months ago #83034
by Mainzer
Thank you nicolas,
that was exactly what I needed to know
