Categories of products
13 years 10 months ago #83803 by sorin21us
I want the categories of products menu, that is on the left side, bottom, on demo page
to be the default menu on top of every page.
Please someone tell me how to make that menu, because on the demo website, from hika, that is a hidden menu and I don't understand if I want to make it for me, how to do it.
For 2 months I tried to understand hikashop and i failed every time. That's why I asked for help from you.
13 years 10 months ago - 13 years 10 months ago #83856 by Mohamed Thelji
It's not a menu but a module, so I think that you should see how the module with the id number 120 is configured through "Hikashop->Display->Content modules" and the Joomla module manager.
Hope this will help you.
Last edit: 13 years 10 months ago by Mohamed Thelji.
13 years 10 months ago - 13 years 10 months ago #83921 by sorin21us
Replied by sorin21us on topic Categories of products
Thank you Mohamed. That helped me to make the module. But now if I click on any category from the menu I get 404 - Article not found.
Please can you tell me why I get that?
Last edit: 13 years 10 months ago by sorin21us.
13 years 9 months ago - 13 years 9 months ago #84000 by Mohamed Thelji
Can you disable the SEF in Joomla > Global configuration ?
I think that it will maybe resolve your problem.
Last edit: 13 years 9 months ago by Mohamed Thelji.
13 years 9 months ago #84114 by sorin21us
U r wright, the menu works if I disable SEF.
But in the final I don't want the SEF disable.
So pls tell me, what can I do to have SEF on and the menu to work?
13 years 9 months ago #85185 by nicolas
Replied by nicolas on topic Categories of products
That's because in the "menu" option of your module (in the hikashop options of the module), you need to select a hikashop categories listing menu item. However, the SEF system of Joomla doesn't know how to display the page of the links of your module.
The following user(s) said Thank You: sorin21us
13 years 9 months ago - 13 years 9 months ago #85524 by sorin21us
Thank you Nicolas. Works, but after I did this modification when I select "All" from pagination, shows me only one product.
I saw that is the same in the admin area. So far, the products are only in the Men Subcategory.
This is the website .
Last edit: 13 years 9 months ago by sorin21us.
13 years 9 months ago #85640 by Jerome
Replied by Jerome on topic Categories of products
The "All -> 1" problem has been fixed for the next released.
You can look at the fix here: www.hikashop.com/en/forum/4-how-to/76946...1-product.html#83120
13 years 9 months ago #85710 by sorin21us
Thank u Jerome. That works for the front end. I tried to look for the same code, in the same file, in back end, but I didn't find it. In the admin area, for hikashop product, if I select all, is sending me to the page to add a new product.
Can u pls help me with this one, too?
13 years 9 months ago #85780 by Jerome
I can't reproduce your problem in my local website or in the demo website.
Please be sure that you didn't click on the "new" button and use the "back" button just after.
The default task is empty in the product listing so, such bug is not possible.
13 years 9 months ago #85885 by sorin21us
You are right. That problem was in admin area before I changed the <=. After I cleared recent history from browser I didn't have the problem with All in admin area.
