problems with pagination
- VeraDantas
13 years 9 months ago #87514
by VeraDantas
problems with pagination was created by VeraDantas
hello,
I have a vertical menu maximenu CK! Access to products is done through it, but I have a problem. Pagination only appears in the categories. when I click on a category to display products pagination disappears and I am unable to access all products.
can you help me?
thank you.
can you help me?
thank you.
13 years 9 months ago #87565
by Xavier
Replied by Xavier on topic problems with pagination
Have you edited any view like "product / show" ?
Do you have choose a menu for the associated module configuration ?
Can you give us a link to your website ?
The following user(s) said Thank You: VeraDantas
- VeraDantas
13 years 9 months ago #87871
by VeraDantas
Replied by VeraDantas on topic problems with pagination
I'm still working locally! : (
i didn't change de product/show!
I put the home page as a list of categories and if i access the list of products through there runs fine.the products anda categories appear automaticly but the same does not happen when I access the products through vertical menu (maximenu).the categories appears but de products dont! I dont now why! To better explain, I did not create any menu in joomla, i put maximenu module automatically on the left in position 7 of my template, for that i creat a hikashop content module to provide on main (position 12)! when i do that the list of products appears without the pagination even whem i access through home!so if i choose one or another method i have always a problem! I do not know what to do. I hope you can help me!
thanks
thanks
13 years 9 months ago #88152
Replied by nicolas on topic problems with pagination
I think that in the maxi menu,you need to select the HikaShop menu where you want to direct your users when they click on the links of the maxi menu module. If it's not done or not done correctly, I think that it could lead to that problem.
I would recommend to contact maxi menu support to confirm that with them and get directions on how to select that menu in maxi menu as I've never used maxi menu so I can't tell you exactly.
- VeraDantas
13 years 9 months ago #88212
by VeraDantas
ok thank you!
I will do this.
I will do this.
