[SOLVED] Backend - Products most viewed
13 years 1 month ago #123826 by aheng5
HI, is there a way to reset the count on most viewed items? I'm creating site on test server and don't want to bring over stats of how many times I've viewed a product during my testing. I have modules set up on front end to also show Most Hits and want to reset to Zero if possible before I transfer the config settings to live site.
13 years 1 month ago #123858 by TWCrap
Hy,
I'm on my mobile now, so i can't check it right now, but i think that you can set the value in the database.
If you've found the right data you can execute an query to set it to 0 views.
If you need any help, ask. Then.i will look at it later on my pc.
13 years 4 weeks ago #123954 by Jerome
You can use the "mass action" in order to change the value of the "product_hit" counter.
The following user(s) said Thank You: aheng5
Time to create page: 0.138 seconds
