How to create fresh installation of HikaShop
13 years 8 months ago #90991 by bencej
I would like to do a fresh installation of HikaShop Starter edition. I have tried to uninstall the existing version, but everything did not uninstall properly and when I tried to reinstall it again not all modules and plug-ins were reinstalled. How can I "reset" the installation so that I can start from scratch?
Jacques
13 years 8 months ago #91082 by Eliot
Hi Jacques,
Indeed uninstalling Hikashop isn't enough if you really want a fresh install.
What you have to do is to look at your SQL base and delete every table with hikashop in their name. This is where the different datas like products are stocked and we don't erase it when uninstalling to avoid data loss.
Hope it will help you
The following user(s) said Thank You: bencej
13 years 8 months ago #91219 by bencej
Thanks. That helped. I was able to reinstall everything again.
