Div configuration does not work
13 years 9 months ago #91170
by phuonker
Div configuration does not work was created by phuonker
Hello
I have the problem that my product does not appear as I was expecting.
I already made a list of 3 and 2 products respectively and they appear nicly. Now a created a new category and placed one new product, but this one does not appear really nice and not like the otheres, although I proceded the same way like the previouse products/categories
here is my link how it should appear: www.pamirjourney.com/index.php/reiseange...10-taegige-rundreise
Here is the link how it appears for the new product: www.pamirjourney.com/index.php/reiseangebote/treckingtour
I was already changing in the menu options within Hika Shop, but nothing happened. I used the "Options for the 'Associated products listing for category listing menu 216'"
I would appreciate very much if someone could give me a hint
Thank you very much
Peter
Thank you very much
Peter
13 years 9 months ago #91208
by Eliot
Replied by Eliot on topic Div configuration does not work
Hi Peter,
Could you please send us a screenshot of your configured module/menu?
I think you maybe configured a too hight number of column or something like that.
13 years 9 months ago #91473
by phuonker
Replied by phuonker on topic Div configuration does not work
Hi Eliot
Here is the printscree. i hope I catched the right one you were looking for. I already tried to change the height and wide parameters, but nothing happened.
Thank you
regards
Peter
Thank you
regards
Peter
13 years 9 months ago #91643
by Xavier
Replied by Xavier on topic Div configuration does not work
Could you give us the screenshot of the associated module ... 216 configuration ?
The links previously given don't work anymore, could you give us links working to see exactly what you need ?
13 years 9 months ago - 13 years 9 months ago #92254
by phuonker
Hello
Thankk you for looking
Here I send you again the link, I change a little bit the name
That's the link how I would like to have it: www.pamirjourney.com/index.php/reiseange.../14-tage-kirgisistan
That's the link where it is wrong: www.pamirjourney.com/index.php/reiseange...isistan-trekkingtour
Thank you
Peter
Thank you
Peter
Last edit: 13 years 9 months ago by phuonker.
13 years 8 months ago #92323
by Xavier
A strange thing is that you have two times the module "128" but displaying different products. It should display the same products, or you should have two different modules.
Have you copy/paste the module ? Try to use another associated module for the menu "trekkingtour".
13 years 8 months ago #92744
by phuonker
Hello
I changed now my associated module and chose 163, but nothing happened. I'm not very sure with your question regarding copping. Basically I chose through menu categories listing, there I set exactly the same parameters as everywhere, so I also chose the same associate module.
What i do not understand is the function of the associate module. As I understood it is just a display help, but could be used several times. Would it be helpful to give through PM my login? I do not see how to solve the problem? Or do you need other screeshots?
Thank you
Best regards
Peter
Thank you
Best regards
Peter
13 years 8 months ago #92858
by Xavier
The associated module is used for the product display options. If the menu is a category listing, so the options of the menu are for the categories, when clicking on a category it display products, and it's now that the associated module options are used.
You can pm the backend access.
13 years 8 months ago #93292
by Xavier
Solved, it was a css issue, I have added the property:
.hikashop_subcategories, .hikashop_products{width: 697px;} in the hikashop frontend css file.
The following user(s) said Thank You: phuonker
