Discount on products for layby
13 years 9 months ago #91697 by gofer123
I just can't get the discount to work, I've gone into Orders,created a new Discount, set at 70% (for layby) gave it a code of lb, set it to discount and not coupon and selected a product but will not work.
www.elandesigndev.co.nz/sapphire/index.php/ball-gowns
Some help for a novice please.
13 years 9 months ago - 13 years 9 months ago #91722 by Mohamed Thelji
Can you show me how did you configured through some screenshots :
- Your discount ("Hikashop->Orders->Discounts->'YOUR DISCOUNT'")
- Your product listing ("Hikashop->Display->Content menu->'YOUR PRODUCT LISTING'")
Thank you.
Last edit: 13 years 9 months ago by Mohamed Thelji.
13 years 9 months ago #91725 by gofer123
Thanks Mohamed,
Hope these are the correct ones?
13 years 9 months ago #91741 by Mohamed Thelji
You should set the "Category" option of your discount to the category "$300-$400" with the ID number 68
13 years 9 months ago #91799 by gofer123
I've done that, now it's only displaying 2 products?
13 years 9 months ago #91895 by Mohamed Thelji
Then you should just set the "Category" option to the category of the products that you want to be in reduction.
13 years 9 months ago #91908 by gofer123
I went into the Discounts window and set the Category option to a category for testing but now it shows a 70% next to the price in Catalog view and in the check out without applying any code.
Don't know what to try next.
Pete
13 years 9 months ago #91927 by Mohamed Thelji
If you want the reduction to be applied with a code, you'll have to set the "Type" option of your discount to "COUPON". Then your customer will just have to use the code which is in your "code" option to use the discount.
13 years 9 months ago #91929 by gofer123
OK, thanks I'll give that a try
Pete
13 years 9 months ago #91935 by gofer123
I'm afraid that doesn't work either
Pete
13 years 9 months ago #91936 by Mohamed Thelji
What did you tried ?
Do you have a coupon step through your checkout workflow ("Hikashop->System->Configuration->'Checkout'") ?
13 years 9 months ago #91937 by gofer123
Hi tried selecting a category then product, the coupon is in the Checkout workflow.
Pete
13 years 9 months ago #92096 by nicolas
Mmm. I see the problem but we can't reproduce it on our end.
We'll need a FTP access to be able to trace the issue.
Could you provide that please via our contact form ?
13 years 8 months ago #93300 by nicolas
I found the problem with the coupon and fixed it. It's working fine for me now on your website.
