multiple products with description?
13 years 9 months ago #92274 by minger1016
I am trying to figure out how to skip a step.
This is what I have:
1. user clicks category
2. it goes to product listing
3. then user clicks product and the description appears
What I need is for user to:
1. click category
2. then it goes to the product list WITH description.
I thought if i clicked the default div setting to display "image and description" it would work, but it doesn't. (see attached) Basically, I have small music samples for sale, so I have embedded the player in each description, so I would like for example, if the user clicks the category "piano" then all of the piano products would be listed with descriptions so the people would see the embedded media player for each and they can only listen to what they want right there without having to click each product again to see the description. Any help would be appreciated.
13 years 9 months ago #92296 by Jerome
The option is the default parameters but it could be override in the content menu.
In HikaShop > Display > Content menu, you would see the category listing which is used by your menu. By editing his options, you would be able to set the type of item layout too.
13 years 9 months ago #92299 by minger1016
I have made the change as you indicated, but it still does not show the descriptions. (see screenshots)
13 years 9 months ago #92345 by Eliot
Hi there,
On your last screenshot the Type of item layout is set to image and title.
Set it to image and description, it should solve the problem.
13 years 9 months ago #92409 by minger1016
Thank you. I changed that setting, and now the description is there, but the formatting doesn't work and also the media player doesn't work. The media player works fine in the normal product description as in attached screenshots. Please advise.
13 years 9 months ago #92453 by Xavier
I think that the answer to you problem is in this post:
www.hikashop.com/fr/forum/5-support-en-f...vue-liste.html#89643
13 years 8 months ago #92477 by minger1016
That's probably good, but that is all in French! I switched to English, but it just changed the titles.
13 years 8 months ago #92533 by Xavier
You have to create a custom field in Display > Custom Fields, the table must be "product", you can call the field "extract"
Then in each product pages, add the tag and the link to the file like, for example: {mp3}path/file.mp3}
Edit the view "product / listing_img_title" and add the code:
<? echo JHTML::_('content.prepare',$this->row->extract); ?>
The following user(s) said Thank You: minger1016
