Disable quantity for some products not all
13 years 7 months ago #92954 by kristianp
I have the Business Version of Hikashop.
I realise that through the standard configuration it is not possible to disable the quantity box for some products but not others. You can turn it off or on but it will refect all products on a global basis.
Elsewhere in the view I have modified options on the basis of the product id e.g. if($this->row->product_id != 13){ blah blah } etc.
Therefore I was wondering can I edit a view somewhere and do the same for getting rid of the quantity box? I could probably do it with a bit of jquery and take it out of the DOM but that is a faff.
Any ideas in which view I should try my idea and where. I have looked in show and show_default but no matter what I do I can't get rid of it for a select few products.
Website is www.meridiancollege.co.uk and if you look at the clever way I have done shipping you will see I am well up for a bit of hacking of code here and there. See also the options for products where I have defaulted them to "Yes" for accommodation products.
Love Hikashop by the way, very clever system.
13 years 7 months ago #92962 by nicolas
Yes, you can use something similar in the "quantity" view file for that:
if($this->row->product_id != 13){ $this->params->set('show_quantity_field',0); }
