Breadcrumbs and related product module
- davideventurini
13 years 6 months ago - 13 years 6 months ago #95221
by davideventurini
Breadcrumbs and related product module was created by davideventurini
Hello, I have the related product module in each products page.
According to the product page I'm visiting, if I click a related product, the path of breacrumbs will be the one with include the category I just seen.
Make an example
Originale product: uomo->tshirt->product1
If I select this product from category UOMO, then TSHIRTS, the breadcrumbs is good.
If I select the same product from a related product shown in category ACCESSORI, the breadcrumbs will be accessori->product1
How can I change the breadcrumbs in the way that it show ALWAYS the real(original) path of the product?
I also using sh404sef and I seen that every time related product loads the products, a new link is generated according to the category where the module were loaded.
Address: www.actionstyleclothing.com
Thank you
Make an example
Thank you
Last edit: 13 years 6 months ago by davideventurini.
13 years 6 months ago #95266
Replied by nicolas on topic Breadcrumbs and related product module
I'm seeing the same links on your website with the example you give.
for example the product www.actionstyleclothing.com/abbigliament...uomo/tshirts/tex-mex
If I access it via the product page www.actionstyleclothing.com/abbigliament...ri/borsa-mare-sailor I'm getting the exact same link and the exact same breadcrumb.
Could you give a precise example ?
- davideventurini
13 years 6 months ago #95352
by davideventurini
Replied by davideventurini on topic Breadcrumbs and related product module
Hello, after I wrote the post I found the solution with the plugin sh404sef.
I modifyed all the url that hikashop generate with the related product, with the one seo optimized.
Thank you
Thank you
Time to create page: 0.193 seconds
