Cart Module Questions
13 years 8 months ago #95549 by condorazul
1.-Is it possible to include images of the product ordered in the cart module?
2.- Is it possible to display the cart in a pop up window? just have an icon your cart an when they click on it displays the cart in a pop up.
13 years 8 months ago #95609 by Xavier
Replied by Xavier on topic Cart Module Questions
You have to edit the view "product / cart" to display the images in the cart. The images are not loaded by default, but you can use a little request to have them.
Like on this topic: www.hikashop.com/fr/forum/5-support-en-f...-affiche-images.html
It's possible but will require too some custom code.
On the link, you will have to load the view "product / cart" and add at the end of the url "&tmpl=component".
13 years 8 months ago #95613 by condorazul
Replied by condorazul on topic Cart Module Questions
cant understand french i suppose that in the last two lines is the code i have to insert?
2.- is it similar to when you create a popup with checkout once you choose an article or its more difficult than that?
13 years 8 months ago - 13 years 8 months ago #95644 by Xavier
1. You need something like:
$db = JFactory::getDBO(); $query = 'SELECT `file_path` FROM `#__hikashop_file` WHERE file_ref_id = "'.(int)$cart->product_id.'" LIMIT 1'; $db->setQuery($query); $image = $db->loadResult();
To load the first image of the product. Thanks to change the var to the corresponding one in the view "product / cart".
Then you need to add the image in the cart table, you can add the image thanks to the code:
<img src="/media/com_hikashop/upload/<?php echo $image; ?>" alt="<?php echo $image; ?>" />
2. It easiest than the popup displayed when adding a product.
You need a link like:
<a title="<?php echo JText::_('SHOW_CART');?>" class="modal" rel="{handler: 'iframe', size: {x: 760, y: 480}}" href="<?php echo hikashop_completeLink('cart&task=showcart',true); ?>"> Show Cart </a>
Last edit: 13 years 8 months ago by Xavier.
13 years 8 months ago - 13 years 8 months ago #95698 by condorazul
I should have done something wrong because it does not work.
The first line of code i should paste it at the start of product cart rigt?
and then where i wantthe image to be displayed add the <td> plus the code</td>.
I did that and did not work so something i did wrong. Sorry for inconvenience
And for the second one i sould create a custom module with that code or i sould paste it in other place?
Last edit: 13 years 8 months ago by condorazul.
13 years 8 months ago #95750 by Xavier
1. In the view "product / cart" you need the var "$row->cart_product_id;" so put the code:
$db = JFactory::getDBO(); $query = 'SELECT `file_path` FROM `#__hikashop_file` WHERE file_ref_id = "'.(int)$row->cart_product_id.'" LIMIT 1'; $db->setQuery($query); $image = $db->loadResult();
After:
foreach($this->rows as $i => $row){ $cart_id = $row->cart_id;
2. You can place this code where you want.
13 years 7 months ago #95998 by condorazul
it does not work for me it displays a error line saying that image variable is not defined.
what i did is paste the code you gave:
if(empty($row->cart_product_quantity)&& $cart_type != 'wishlist' || $row->hide == 1) continue;
if($group && $row->cart_product_option_parent_id) continue;
$productClass->addAlias($row);
and in the table i added the <td><img....</td> code you gave me.
The following user(s) said Thank You: cbenard
13 years 7 months ago #96093 by Xavier
You need to replace "#_" by your database prefix. I think that's why you have an error.
13 years 7 months ago #96393 by condorazul
i insert this code into a custom html module but it does not work, where should i insert it?
Show Cart
</a>
13 years 7 months ago #96418 by condorazul
Same problem undefined variable image.
$query = 'SELECT `file_path` FROM `gp8u6_hikashop_file` WHERE file_ref_id = "'.(int)$row->cart_product_id.'" LIMIT 1';
and the other one
<tfoot>
<tr>
<td colspan="<?php echo $row_count;?>">
<hr />
</td>
</tr>
<tr>
<?php $colspan = '1';
if($this->params->get('show_cart_quantity',1)){
$colspan=2;
<td class="hikashop_cart_module_product_total_title" colspan="<?php echo $colspan; ?>">
<?php echo JText::_('HIKASHOP_TOTAL'); ?>
</td>
<td class="hikashop_cart_module_product_total_value">
<?php
$this->row=$this->total;
echo $this->loadTemplate();
</td>
<td><img src="/media/com_hikashop/upload/<?php echo $image; ?>" alt="<?php echo $image; ?>" /></td>
<?php if($this->params->get('show_cart_delete',1)){ ?>
<td>
</td>
<?php }?>
<?php
if($row_count<2){ ?>
<td>
</td>
<?php }?>
</tr>
</tfoot>
<?php } ?>
<tbody>
13 years 7 months ago - 13 years 7 months ago #96467 by Xavier
Show Cart
</a>
I just tried this code on my end, and it's displaying the cart in a popup when clicking on "show cart". This should work, even if it's in a custom html module.
For the other point, are you sure that you have an image for the product added in the cart ?
Thanks to use "<?php var_dump($row->cart_product_id); ?> to see if the product id is returned.
If not, you have to use another var, else there is no image for this product. In all cases you have to add a check to see if the image is present or not.
Something like:
<td> <?php if(!empty($image)){ ?> <img src="/media/com_hikashop/upload/<?php echo $image; ?>" alt="<?php echo $image; ?>" /> <?php } ?> </td>
Last edit: 13 years 7 months ago by Xavier.
13 years 7 months ago #96522 by condorazul
if i add the last string you gave me nothing is displayed when i add the first one <?php var_dump($row->cart_product_id); ?>
displays: string(1) "5".
i´m sure i have an image on it i
i´m using joomla 3 and last hikashop version.
13 years 7 months ago #96523 by condorazul
i went to joomla modules
new html module
paste the link and
when i use the
Show Cart
</a>
what i get is forbidden access, the object is write protected or cant be readed by the server, error 403.
I´m runing the page in loclhost with xampp and las php version.
13 years 7 months ago #96556 by Xavier
For the image in cart issue, could you give us a backend access ?
13 years 7 months ago #96561 by condorazul
I have the web locally installed but im going to upload it tonight and give you the acess.
Thank you
13 years 7 months ago #96566 by condorazul
I´ve send you the access, thank yo
13 years 7 months ago #96633 by Xavier
Cart image issue: Can you check in your phpMyAdmin in the table "gp8u6_hikashop_file" if there is an item with the file_ref_id "7" ? And try the previous sql request in phpMyAdmin.
Show cart module: You can't add php inside Joomla article by default, you can use a plugin to add php inside.
13 years 7 months ago - 13 years 7 months ago #96668 by condorazul
I installed direct php but it does not open the cart in a modal window instead of it it redirect to a cart in the same page and to directly print the cart.
and in the database i only have file_ref_id 1,2,3,4 no more.
What do you mean with try the previus request in phpmyadmin???
Last edit: 13 years 7 months ago by condorazul.
13 years 7 months ago #96727 by Xavier
Show cart module: you don't have declared the behavior modal in your template, that's why the popup is not working. Try to add <?php JHTML::_('behavior.modal'); ?> in the head part of your template.
Cart image issue: You should have an entry for the file_ref_id '7'. You can try to remove the image and set it again.
We are adding an option to display the images in the cart. It will be in the next release.
13 years 7 months ago #96842 by condorazul
both did not work, i added behaviour modal in firs line in template.php nothinghappens
deleted image and reup and did not work too.
Next release when it would be ready?
Time to create page: 0.165 seconds
