Cart Module Questions
13 years 7 months ago - 13 years 7 months ago #96951 by condorazul
Replied by condorazul on topic Cart Module Questions
All right i managed to do several things, first thanks to widgetkit i managed to display the cart ina modal window without problems, but the url in php you gave me leads to a kind of customer cart or multicart, you can put name to the cart an add to wishlist or convert cart to wishlist, but you cant continue to chekout.
What i really would like is to be able to display hikashop cart module in a modal window but i cant get the correct url to do that.
Last edit: 13 years 7 months ago by condorazul.
13 years 7 months ago #97269 by Xavier
Replied by Xavier on topic Cart Module Questions
The cart module view is in "product / cart".
To call this view, the code:
<?php if(!defined('DS')) define('DS', DIRECTORY_SEPARATOR); if(!include_once(rtrim(JPATH_ADMINISTRATOR,DS).DS.'components'.DS.'com_hikashop'.DS.'helpers'.DS.'helper.php')){ echo 'This module can not work without the Hikashop Component'; return; }; $js =''; hikashop_initModule(); $config =& hikashop_config(); $module_options = $config->get('params_'.$module->id); if(empty($module_options)){ $module_options = $config->get('default_params'); } foreach($module_options as $key => $option){ if($key !='moduleclass_sfx'){ $params->set($key,$option); } } foreach(get_object_vars($module) as $k => $v){ if(!is_object($v)){ $params->set($k,$v); } } $params->set('cart_type','cart'); $params->set('from','module'); $html = trim(hikashop_getLayout('product','cart',$params,$js)); if(!empty($html)){ ?> <div class="hikashop_cart_module" id="hikashop_cart_module"> <?php echo $html; ?> </div> <?php }
is used. So you can maybe create a view, use this code inside and call the created page in your link.
13 years 7 months ago #97794 by condorazul
Ok finally i managed to do it and it was much simplier than that.
the only thing we have to do is add in the href="#hikashop_cart"
so the cart is displayed!!!
