Category and products below in stead of row
13 years 8 months ago #95960 by vlaspo
I have a small problem, when i installed the Hikashop clean and created some categories and products I see that these items are listed in 1 row and not as default as 2 or 3 items in a row.
also i miss the border around the products.
See also the example on the PAGE
I am looking for the solution like this PAGE
Does someone know to do this
13 years 8 months ago - 13 years 8 months ago #96028 by Xavier
You have to go in HikaShop > Display > Content menu, edit the menu "Cursus Aanbod" and change the number of columns in the options of this menu.
Last edit: 13 years 8 months ago by Xavier.
13 years 8 months ago #96053 by vlaspo
I have already found this and this was not the solution.
See as well the attachment.
when i change the template to "protostar" then i see the correct settings. (see attachment 2)
when i use the template "beez3"then the wrong layout is visible again.
13 years 8 months ago #96067 by Dafilla
I have had this once (only occured in Joomla 3) and for me it helped to switch of the 'use bootstrap design' in Configuarion-System-Display-3rd option.
The following user(s) said Thank You: vlaspo, dngu3355
13 years 8 months ago - 13 years 8 months ago #96073 by vlaspo
Yes this solved the issue.. Many Thanks!
Last edit: 13 years 8 months ago by vlaspo.
The following user(s) said Thank You: dngu3355
